Will progress drop springs from a 2000 4cy Accord Sedan
Parting out 02 Type S :(
Originally posted by brianlin87
i had progress springs/koni yellows it wasn't too bad... but really really low
a progressive spring as i am sure most know, works with a generous spring rate which increases as the spring compresses. this gives a good ride for most surfaces, and it helps when the spring is pushed in during cornering.
now, if you take these springs from designed for a car weighing at least 500 lbs. different than yours, and having a diff. f/r balance, you will screw up the progressive rate design.
think of it this way, your car will think that you are constantly cornering since the spring is compressed heavily. the more spring is compressed on prog., the ride gets worse.
snorf
11-04-2019 06:44 AM
1fatcrxnem1
22
06-01-2018 01:23 AM
NBP_BALLER
09-23-2015 08:18 PM
