whos got one?
Old Jun 22, 2009 | 08:50 PM
Rajca's Avatar
wham bam thank you ma'am
whos got one?
just installed it. took about a hour bc of figuring out how to mount it. i feel more vibrations inside the car which isnt a problem and its not that noticable. still have to test drive it and put longer and stronger bolts in. the ones that came in the package are short and i dont like it.
best part. its not made for our model, but still bolts right up. no cutting, drilling, or custom fab required. has plenty of room all around it
next will be the 60a or 80a polly fill motor mounts. then a custom traction bar since one isnt available for us
Old Jun 22, 2009 | 10:10 PM
ThegreatGATHby's Avatar
What was the part number for the NRG damper? They used the same picture for all of them online.
Old Jun 22, 2009 | 10:12 PM
civicdrivr's Avatar
I dont have one.
I have two
Old Jun 22, 2009 | 10:16 PM
AnthraciteBeast's Avatar
^ nice
Old Jun 22, 2009 | 10:18 PM
Rajca's Avatar
^nice. im gonna replace my rear one with a nrg one also. just need to get it.
part number, dont have one by me, will get it tomorrow when i go into my garage.
Old Jun 23, 2009 | 12:28 AM
StreetKA's Avatar
i think i need one too. how much is it ? got link ?
Old Jun 23, 2009 | 02:19 AM
jl03CLS's Avatar
6speed
i used to have 2...but then one fell out
whats with the bracket at the top?
Old Jun 23, 2009 | 02:47 AM
nf3d0149ab's Avatar
I forgot about these...
Old Jun 23, 2009 | 04:40 AM
Rajca's Avatar
i payed $90 for it. got it off the black market, so no link. ill get the part number this afternoon.
what do u mean? thats how its held on. the oem one, i can compress with my hand with little effort, what a shitty design.
Old Jun 23, 2009 | 06:44 AM
Pseudomaniac's Avatar
I never found much use for them - puts strain on the train....
Solid motor mounts if you're wanting that kinda hookup.
Old Jun 23, 2009 | 08:33 AM
NRG sells them on their website for $89.99, so there should not be a supply issue.
Old Jun 23, 2009 | 08:48 AM
civicdrivr's Avatar
I think I got it for either an EG or EK Civic for around $60 a piece.
I didnt use the mounting bracket that NRG supplies, I used the stock mounting bracket. I dont have the pictures on this computer though. Right now Im running with only the front one. I lost the bolt that holds the bracket on for the rear when doing the mounts.
Just check it every now and them and make sure its still in one piece. I had to retighten everything 3 times, until I finally put thread tape on everything.
Old Jun 23, 2009 | 09:21 AM
Rajca's Avatar
The stock dampner, I can compress with my hand. So this is an improvement. Just like if u were to polly fill the mounts
Old Jun 23, 2009 | 11:07 AM
jl03CLS's Avatar
6speed
i also got the damper for the civic. On my damper the top part was removed and a bolt was put in place so you can mount it in the stock position. lemme find the link real quick
Old Jun 23, 2009 | 11:14 AM
jl03CLS's Avatar
6speed
https://acurazine.com/forums/2g-cl-2001-2003-50/6-speed-engine-torque-damper-installed-484603/
Old Jun 23, 2009 | 06:50 PM
GreenMonster's Avatar
Thanks... you saved me the trouble of having to find the thread...
Hmm... Merge the threads or not ??
Old Jun 23, 2009 | 06:52 PM
Rajca's Avatar
idk, two diff ways of installing a dampner
Old Jun 23, 2009 | 09:41 PM
jl03CLS's Avatar
6speed
no problem.
interesting way of doing it. do you still have the stock damper in place with the nrg next to it?
Old Jun 23, 2009 | 09:44 PM
Rajca's Avatar
no problem.
no. took the stock pos out. drove the car today still got some wheel hope but not as bad as last time. still need to do the rear damper and polly fill my mounts.
Old Jun 23, 2009 | 09:58 PM
Alperovich's Avatar
6spder
i got one on my coupe, no rattles thou
