Who's got nitrous?
repost
13.25 @ 105.7
beat it, nga.
beat it, nga.
yeah, I wouldn't recommend spraying past 7100 rpms.
hoss
So what about the longevity of nitrous. How does this affect the engine with continual use. By this I do not mean using it everyday and using an unsafe amount. I mean if you used it moderatly and used say a 65 or 75 shot. Does anyone know how this would where on your engine or would it be just like using a forced induction kit.
318whp/289wtq @ 6psi
What's up Steve. I believe Mitch(acuracls6spd) has nitrous on his Cl 6 speed. I can't remember which setup he runs but I believe he ran some low 13s with his setup. He's the one with the red car with the carbon fiber trunk.
By the way, when I was running nitrous. I got my tank filled up at Speed unlimited but don't who else sells it.
Never had a clean run
Originally Posted by CLsuperhero
you had to have an almost perfect reaction time.
Originally Posted by shineynitelite
so did you ever strap the bottle
I sprayed in first as soon as I got traction. Spaying from 2nd only netted mid 13's if I remember correctly.
there's a thread in here somewhere that documents all of my nitrous runs.
I'm a Vagiterian.
Originally Posted by mattg
strap the bottle?
Did you have a button, or the brain that did it all for you? I'm skurrr'd that since it's most likely a full-throttle switch, it may spray while the tranny is in neutral shifting gears and do all sorts of bad things.
NAWWWWSSSSSS
1 Post
strap the bottle?
NAWWWWSSSSSS
1 Post
I'm a Vagiterian.
if you have any doubts just get a button, or if you have the money get a window switch
