Where to mount a Basslink
I just installed a Basslink in the trunk (2001 CL-S). It sits on the left side of the pass through up against the seat if you are looking into the trunk from the outside. Basically the front left corner of the trunk.
What's the best way to mount it so it doesn't move? Should I screw into the body below?
Thanks for the help in advance.
Re: Where to mount a Basslink
Riceburner: Basslink - http://www.sjgreatdeals.com/inbasselsubs.html
Originally posted by riceburner503
I just send u PM...How much did u get yours for ?
Nice...how does it sound compare to stock and how long did it take u to install?
It takes about an hour to install. Pretty easy.
[QUOTE]Originally posted by Dom418
i have mine here, and it seems to work well:
I have mine in the same place. What did you screw the footings into? The particle board or the actual body of the car? How did you secure it to the floor?
No, no, no bungee cord the basslink......it holds it in place better.....sounds better because its tighter in the corner. I'll post pics later if ur interested. Also if you take ur car to the drags all u have to do is take the fuse out from the front by the battery and unbungee the basslink and disconnect takes all but 1 minute.
I LOVE MY CAR
Originally posted by night_vision
Are you guys still using OEM Bose speakers? How is the sound from those OEM Bose speakers?
They are OK, but the basslink adds a nice little thump to the stock setup
Installed the Basslink. Sounds great. Thanks for the help. I also found a black bungee cord at Target. That is how I mounted it in the trunk. I mounted the bass control remote in the blank spot next to the dimmer for the dash lights. Worked out great.
Why did you install it upside down to make room for the ski compartment? Looks good but is the bungee adjustable or a specific size. My bungee is adjustable so I can make it smaller if I want to tighten it more. Looks like it's snug.....good job but I would prefer if the "INFINITY" is right side up?
this is where mines is mounted
http://community.webshots.com/photo/...59426386geUrqf
u think the sound quality is better in the back right corner, should i move mines there?
joflewbyu2
10-08-2015 11:16 AM
