Where does the tranny fluid go in the 6 speed tranny? (pics)
??? I'm a bit confused. The only bolt I unbolted had a spring in it with balls in it (the black bolt in the very last pic to the right). Not sure if that's where it would go...And when I took the spring out, I didnt pay attention if the spring went on a ball, or if the spring was seperated from the balls?
THE J35A2...
there. Allout show it all out lol. and don't over fill and do not use synchromesh friction modified, it's too thin! regular synthetic synchromesh will be fine...
THE J35A2...
Originally Posted by Allout
Is Syncromesh better than the new Honda reformulated MT fluid?
2 bottles of reg GM modified and 1 of GM friction modified
Blown is Best
There is a check ball and spring under each of those bolts. Drop the ball into the hole first, then the spring, and then screw in the bolt.
Blown is Best
Originally Posted by SIRSIG
never tried that yet, but i would assume it's gonna work fine like GM and Pennsoil. i heard from NSX guys that they mixed the friction modified with reg modified.
Off topic but how's the clutch?
THE J35A2...
I think I'm going to try the Honda stuff next.
still the same as day one second time i went to the track last night did som crapy times again 14.1@105mph with 2.4 60' that's near you. LACR almost everybody couldn't get traction. i do better on Irwindale (1/8 though) with 2.0 60' 8.53@90+mph with better tires next week i'll let you know...
Blown is Best
THE J35A2...
Are you going to the All-Cali meet in June? I would love to check out your car.
I overfilled the tranny last night and drove it around the neighborhood once, and then it sat in the garage for 11 hours before I drained it from the overflow bolt. I overfilled it by a lot I think. (I guess it wasn't completely drained)
Do you guys think damage could have occured in that small period of time?
Blown is Best
Nope. There's an overflow. If you end up with fluid dripping from between the motor and gearbox, you'll know the souce.
Thanks everyone for all the help
nanos
11-12-2015 08:41 PM
HeloDown
09-08-2015 06:51 PM
