Where can I find 5mm Wheel Spacers?
Blown is Best
I just ordered the Rotora kit. Anyone know of a good source for the 5mm spacers? H&R has a listing but the one place I checked was out of stock. Also, what is a good price for 4?
Thanks,
Thanks,
cheapest I found was on www.optauto.com They sell the H&R spacers.
Blown is Best
Thanks Smitty - I'll wait until I hear from you.
mushutofu - optauto.com is the one I checked but is currently out of stock. I guess they can order if I can't source elsewhere.
Thanks Guys
Thanks Guys
Re: Where can I find 5mm Wheel Spacers?
Thanks,
Thanks,
Discount Tire Center
(5mm) 5X114.3 Bolt Pattern.
Speak to Vick, he knows his stuff. 626-579-1182
1070 Valley Mall St.
El Monte CA 91731
Should be $15-20.00 a piece for Very good spacers... Do not screw around with cheap Spacers... if you can get away with 3mm spacers then do it.. But GET 4 spacers...you want everything the same all the way around the car...
Anything larger than 5mm then you need to go with new HUBS.
AND REMEMBER.. that LUG nut needs to make (6) COMPLETE 360 degree turns when you put those wheels back on, if it does not then you better look into new hubs of different rims.
El Monte CA 91731
Blown is Best
Thanks Smitty, I'll call him tomorrow and get them on order.
As far as 3MM vs. 5MM, these are going behind stock 03 CL-S wheels. Will 3MM work? I thought I had to go 5MM.
Blown is Best
Rotora 13". I don't think I have the energy to powder coat them in black even though there's a powder coating booth 75 yards from me right now.
5mm will be just fine.. I run my stock 03 set-up on HTR+'s in the winter.. 5mm is needed to clear the Rotora 4 piston calipers..
make sure you get (4) 5mm spacers and put 1 on each rear HUB ...stock lugs are fine.. that is what i use and they make more than 6 complete turns... so your safe there.
I run 3mm on my 18 inch SSR GT3's in the summer, hence they are 18 inch and I have more clearance.. But it all depends on the offset of the rim...
So in the futue, if your Rim shopping keep that in mind.
Beware of leakage
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
pray to the man upstairs you never have to strip powdercoating!!
it was not EASY stripping my calipers of the powdercoating with M.E.K. Methel Ethel Ketone... it is not only dangerous, but VERY time consuming... that shit causes major nervous sytem damage if you inhale it...
Blown is Best
Blown is Best
Those bastards at Rotora wanted 400 extra dollars to powdercoat them black.. that was just the 2 front ones too..![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
I thought about it until I read your write up. I think I'm going to live with the Red. Wish I could get them to send me unfinished calipers but that ain't happening.
If I could rant:..... Honestly I learned alot about modding this car... I must say to anyone new that decides to mod their car.. GO with what you wanted the first time.. DO NOT settle for second best, even if those fansy rims/brakes/headers, etc cost alittle more.. SAVE UP and get them.. do it right the first time around..
P.S. something you should know.. the labels on the brake kit.. telling which caliper and which rotor go where?.. they are backwards.. so make sure you lay everything out and do it right the first time..
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
cammy5
09-04-2015 11:26 PM
mtl_ilx
09-03-2015 09:48 AM
