When Should I Do My Maintenance?
Old Dec 5, 2006 | 01:51 PM
dannyboi's Avatar
ImA King
I have a 01 CL-S It has 82k and im wondering when should i give it a complete tuneup or what should i do to it so things wont go bad on me .... Any thing i should change in particular? Thanx
Old Dec 5, 2006 | 01:59 PM
RaviNJCLs's Avatar
Have you had any service done on it before? If it's working fine, I'd just do the basics. Plugs, filters, fluids.
Old Dec 5, 2006 | 02:26 PM
dannyboi's Avatar
ImA King
i just got the car at 80k... i dont think it has the 90 k done yet but is there anyother thing i should worry about he told me i should definately change the transmission filter or something like that
Old Dec 5, 2006 | 02:48 PM
RaviNJCLs's Avatar
I never really did a ton of the prescribed maintainance. I would recommend having it checked out first. Some of it, you can do yourself. Checking the color of the tranny fluid is simple enough, but may not tell you the entire story. Checking the condition of the plugs and air filter is something you can do in about 10-15 minutes.
Whenever I buy a car, I take it to my mechanic and have him take a closer look at it. If you have someone you trust, I say take it there. The dealer will be a bit costly.
Old Dec 5, 2006 | 03:58 PM
phipark's Avatar
Not Asian
Do you have a manual? If so, read it.
Old Dec 5, 2006 | 05:58 PM
GreenMonster's Avatar
And if you don't have a manual, read the FAQ forum here, and this post in particular:
https://acurazine.com/forums/showthread.php?t=178269
I have the links to the acura owners site (which has the maintenance schedule) and a link to a pdf file of the maintenance schedule...
Old Dec 5, 2006 | 08:28 PM
Allout's Avatar
Blown is Best
If you have an extended warranty up to 100K, I would do the timing belt service before you get to the 100K in case anything is found when they do the service. I had a leaking water pump and leaking output shaft seal that got replaced under warranty that were found during the service.
acuratl26
Apr 23, 2020 07:30 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
polish_pat
Sep 30, 2015 12:22 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
