When Should I Do My Maintenance?
I have a 01 CL-S It has 82k and im wondering when should i give it a complete tuneup or what should i do to it so things wont go bad on me .... Any thing i should change in particular? Thanx
Originally Posted by RaviNJCLs
Have you had any service done on it before? If it's working fine, I'd just do the basics. Plugs, filters, fluids.
Originally Posted by dannyboi
i just got the car at 80k... i dont think it has the 90 k done yet but is there anyother thing i should worry about he told me i should definately change the transmission filter or something like that
Whenever I buy a car, I take it to my mechanic and have him take a closer look at it. If you have someone you trust, I say take it there. The dealer will be a bit costly.
Originally Posted by phipark
Do you have a manual? If so, read it.
https://acurazine.com/forums/showthread.php?t=178269
I have the links to the acura owners site (which has the maintenance schedule) and a link to a pdf file of the maintenance schedule...
If you have an extended warranty up to 100K, I would do the timing belt service before you get to the 100K in case anything is found when they do the service. I had a leaking water pump and leaking output shaft seal that got replaced under warranty that were found during the service.
acuratl26
Apr 23, 2020 07:30 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
