View Poll Results: Comptech Clutch/flywheel kit or underdrive pulley?
55.56%
Underdrive pulley
44.44%
Voters: 9. You may not vote on this poll
Whats the best mod to get? Comptech Clutch/flywheel kit or Underdrive pulley??
I know i can't take both... it would be a disaster..
So? Whats the best mod to get?
Flywheel/Clutch:
Much better flywheel and clutch then oem
Good weight reduction in the front of the car (25lbs)?
Car responds better during accelleration
Dosent add any HP,
Pricey
Underdrive pulley:
Adds maybe 5 to 8 whp
Small weight reduction (5lbs)
Inexpensive
Flywheel/Clutch:
Dosent add any HP,
Pricey
Underdrive pulley:
Inexpensive
"""""""I know i can't take both... it would be a disaster..""""""
Why not?????????
I went with a Light weight G60 Flywheel and VR6 clutch in my 1.8T Jetta and loved it. Reved much quiker, and made full boost a bit earlier than normal.
I have the Option Racing Crank pulley on my CLS now and like it. Seems to pull better in the lower RPM range. Less pedal to get going too.
For you I'd say go with both. You can afford it if you are considering the Flywheel. The Option Racing pulley is like $24.00 Shipped. Going both will maximize you gains. I think they would complement each other well.
Why not?????????
Why not?????????
Why not?????????
Originally Posted by CivicB18B1
Ok, thats a five year old post. and the problem might have been fixed.
But I don't see anything about using the Crank pulley and light weight flywheel together. Why would that be a bad combo.
Seems like all that thread would do is answer you original question about the flywheel. Does'nt seem to have anthing to do with the both of them being used at the same time.
Doing both is flirting with disaster.
Trolling Canuckistan
Underdrive pulley:
Inexpensive
Inexpensive
Originally Posted by Allout
You're removing all the dampening from the crank when you go a lightweight flywheel and pulley. With the Comptech flywheel, you still use a stock pressure plate and it's the weak link. If there was a stronger pressure plate, then it may be worth risking.
Originally Posted by L's TL
If you read on you'll see that using both together destroyed transmission components
That would be awfully hard to figure out! I'll bet it was just speculation! There are so many other contributing factors.
Good luck, either way you go!
i agree but the risk is too great. there were a few people who tried it thinking that it was just coincidence and realized they just had a $1500+ bill on their hands. Better safe than sorry IMO
BoricuaTL
04-08-2016 01:08 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
