What'd I do wrong... (1/4 times)
#42
Originally posted by mrsteve
Is there really almost a 40 whp gain with headers and intake???
Also... if I shifted at 6200 rpm... wouldn't my rpms in 2nd gear start much lower... say around 3700 rpm? That can't be good. I've never heard of people NOT shifting at the redline while racing.
p.s. when should i shift according to this dyno
[IMG]http://www.tamparacing.com/forums/at...&postid=842780[/IMG]
#43
Happy CL-S Pilot
Headers and Intake will realistically add some PEAK 25-30 WHP. With Mike's dyno it was close to 40 WHP, he had a tunable strong CLS-5AT.
#45
You bought a slow ass cl. iT IS A SEMI LUXURY CRUISER WITH SOME PASSING POWER.
Not a drag strip car.......
Trust me I own one after having an 11sec 86 buick regal and a 12 second !995 Tbird SC
#46
Happy CL-S Pilot
TypeR,
With your dyno and T: 50F, RH: 30% AP: 30.5", Dry Density Alt: -1045'. and BT to 2400 rpms, shifting at 7100 rpms.
Tue Nov 25 03 6:16 pm
Time Slip For: 2001 Acura CLS Import moded 244 WHP TypeR Dyno
RT .500
60 ft 2.322
330 ft 6.062
1/8 ET 9.133
1/8 MPH 80.83
1000 ft 11.804
1/4 ET 14.052
1/4 MPH 100.55
If I let the computer select the shift points, it shifted at 7050 rpms
and.... no improvment.
Tue Nov 25 03 6:24 pm
RT .500
60 ft 2.323
330 ft 6.069
1/8 ET 9.145
1/8 MPH 80.67
1000 ft 11.821
1/4 ET 14.071
1/4 MPH 100.45
RT .500
60 ft 2.322
330 ft 6.062
1/8 ET 9.133
1/8 MPH 80.83
1000 ft 11.804
1/4 ET 14.052
1/4 MPH 100.55
RT .500
60 ft 2.323
330 ft 6.069
1/8 ET 9.145
1/8 MPH 80.67
1000 ft 11.821
1/4 ET 14.071
1/4 MPH 100.45
#47
![Loser](https://acurazine.com/forums/images/smilies/loser.gif)
Also, I'm not building my car to be a "drag strip car." Just wanted to get the most performance out of my "semi luxury cruiser w/ some passing power"
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
If you really had no reason to reply other than to hate you need not reply again. I was looking for helpful responses, not ones bragging about a 20 year old Buick. :thumbsdn:
#50
Originally posted by Nashua_Night_Hawk
TypeR,
RT .500
60 ft 2.322
330 ft 6.062
1/8 ET 9.133
1/8 MPH 80.83
1000 ft 11.804
1/4 ET 14.052
1/4 MPH 100.55
RT .500
60 ft 2.323
330 ft 6.069
1/8 ET 9.145
1/8 MPH 80.67
1000 ft 11.821
1/4 ET 14.071
1/4 MPH 100.45
TypeR,
RT .500
60 ft 2.322
330 ft 6.062
1/8 ET 9.133
1/8 MPH 80.83
1000 ft 11.804
1/4 ET 14.052
1/4 MPH 100.55
RT .500
60 ft 2.323
330 ft 6.069
1/8 ET 9.145
1/8 MPH 80.67
1000 ft 11.821
1/4 ET 14.071
1/4 MPH 100.45
#52
Originally posted by darrinb
u only put down 244 type R??
seems low, the max power is at 6500 and slowly dies to fuel cut off
#53
Happy CL-S Pilot
Originally posted by typeR
wow so im better then your computer...can you change the 60' to 1.90 and see what that changes...BTW my first day at the track with the 3.5 i went 9.145 in the 1/8th
#54
It's the area that counts unless your going for a salt flat run...
Ask typeR to dig-up the tape of the car burning the tires in first and second gear (with good tires).
Forget about peak/max HP unless you buy a 7-speed gearbox or CVT (or are interested in top-speed runs). Look to the tq/hp area gain (compared to stock) in the “useable” powerband.
The rod ratio is altered in a 3.5 and the intake air is moving a lot quicker at lower speeds (that longer stroke pulls on the air harder/earlier). Breathing at higher speeds becomes an issues and some upper end breathing design could push the peak HP a lot higher with a cam, head work, and other mods that would increase volumetric efficiency at 6K- to 7K- rpm.
#55
6th Gear
With my old car (Grand Prix GTP) I was seeing consistent 60 ft's of 1.8, 1.9, 2.0 being the worst of them...this was with bulletproof axles, LSD, and slicks....but since I'm new to the CL's...what is considered a good 60ft? I've been racing for years, mostly American, and haven't gotten the CL to the track...I have all winter and early spring to mod...tracks don't open around here until about March
#56
BTW, what year was your GTP and were you on the old Listserv Brian ran??
#57
Oh and I was running 2.2 60's all day long. 1st time to the track too.
#59
Re: It's the area that counts unless your going for a salt flat run...
Originally posted by EricL
Area under the curve is what does it.
#60
mrsteve,
did you fix you CLS? is the IMRC replaced.
Nashua
mrsteve,
Nashua
#61
Voting "non-functioning IMRC" because my only "mod" was a hi-flow comptech air filter (and removed the resonator box from the intake path) and I was definitely in the (high) 14s. Then again maybe my car was strong and yours is a weak one? ![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
NOVA had about 300lb weight disadvantage between our cars and he had CAI, headers, exhaust and I slightly pulled on him. Maybe it was a fluke but hey it happened.
edit - should have read the rest of the thread. so it was that. cool. glad that's fixed. =)
#63
a buick and a tbird huh
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
i guess jealousy can really get to some people
#64
Went to the track. MUCH better results. See them here:
http://www.acura-cl.com/forums/showt...hreadid=122786
