What are the symptoms of running lean?
Censored User
From: Miami - just one day, I would like to drive without getting cut off!
Didn't want to hijack anyone else's thread....So when you're running the 1/4 mile what would be the result of running lean and running rich? time wise 60 feet and 1/4 ET?
Depends on how far in either direction. Too lean and you start melting pistons. To rich and the car will spew smoke and possibly back fire. Not as extreme as mentioned above but outside of ideal would result in about the same thing either way; slower times. Too rich and the combustion is too cool limiting power. A little too lean and knock can start which when the ECU hears it will back off on timing. This also kills power.
But if you had to go to one side of optimal, side with running too rich.
Below is an example of power between a properly tuned car and one which is having fuel issues; turned out to be the FPR. The first plot is from my first dyno with the blower which confirmed there was a problem which I ended up fixing. The second plot is with a properly functioning FPR. That is a significant difference between proper tuning and poor tuning.
Re: What are the symptoms of running lean?
To be sure, you would need to pull plugs out during a full power run and cut power instantly to look at the plug color. I don't think that would be too practical as the plugs are not exactly a 2-minute operation to pull (on some cars, it only takes a few seconds to spin a plug out to get a "read of the plug color")
So, you probably want to be near 12.8-13:1 fuel air at full throttle if you’re not using S/C, turbo, NOS (F/I) (I presume your N/A).. If you are using S/C, turbo, NOS, you would want to keep the car rich to protect it.
So, would you be willing to head to a dyno shop for a few pulls (make sure you tell them you want the fuel-air monitored during the pulls -- they will hook up a wideband 02 sensor and you will know what's up.)
An EGT (exhaust gas temp) sensor and/or wideband 02 sensor would keep an eye on your air-fuel and exhaust temps from idle to WOT.
And, don't forget about the actuator.
BTW, I would mention looking at the tail pipe for black smoke (too rich), but you would have to really be burning pretty rich to get that. And, if you are too lean, you are probably going to overheat something and melt a piston. You'll get detonation if you're running too lean at full power.
Censored User
The reason I ask is, when I tracked my TLS I had some controversial yet excellent 60' times, but horrible ET's in relation. My car was stock at the time. Later I got some headers which I removed when I bought my CLS 6MT. A guy at a do it yourself autoshop looked at the headers and said I was running lean. They're kind of purple and goldish in color. So I was wondering if running lean would cause a good start but poor finish? Or could it have been something else, poor driving, or a fat ass!?!?
Censored User
Censored User
Originally posted by EricL
The SS header aging process makes for some interesting colors/hues... And, they don't need to be running lean to get that golden color...
Originally posted by mrsteve
Scalbert is that 323 wheel hp???
Kudos.
Since I got my s/c I noticed I have black carbon build up around my exhaust outlets all the time. I wipe them down every few days but I can't believe how fast it comes back. I wonder if I am running too rich? I know it wasn't like that before the s/c.
Just so I understand correctly, there was some other stuff going on besides just correcting your a/f to get that much increase in power. But the WHP is stunning, more 100 WHP over stock!!!! Before the I/C Manifold!
Now with the IC my goal is to make 150 WHP over stock.
The additional power is not without some drawbacks.
Believe me, I'm not complaining
It does run richer than stock when at or near WOT with the SC. Any time when into boost the car runs much richer than it would have without the SC at the same throttle input. So additional soot on the tail pipes is to be expected.
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
