What Plugs to use with NOS???
I did a quick search but didn't find what I was looking for. I just ordered NGK IRIDIUM Plugs and a ZEX 82011 NOS kit. and affter reading the instructions online fo r the ZEX site states: "The correct
solution is to replace the plugs with units that have shorter ground straps. By doing this, you will shorten the heat path from the ground strap to the plug base. ZEX™ Hyperformance™ spark plugs are recommended for many applications."
What do you think. Can I run the NGK's? or did I just wast my money on something I can't use?
well, the site is correct. but i hope you are getting a better fuel pump. i dont think i know which plugs are exactly needed, but you should be fine as long as you run the highest octane gas possible and get a HIGH PERFORMANCE FUEL PUMP.
Nox is not dangerous when done correctly
You need to run #7 plugs
NGK 4091 (V-Power) Cheaper route
NGK BKR8EIX-11 (Iridium) Better route
The nitrous kit 82011 is a Dry nitrous kit. I would recommend a wet nitrous kit for your car; however, i guess it will not make to much a difference as these cars have a fuel return.
ITSJESTER
17
Dec 6, 2018 02:29 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
