What I need before SC Install
#44
Blown is Best
https://acurazine.com/forums/showthr...ight=IMRC+Dyno
https://acurazine.com/forums/2g-cl-dynograph-gallery-51/cls-01-263hp-220tq-51k-480581/
The IMRC helps with the low end on our motors. Under normal driving conditions and light throttle, you may not be in boost and your motor is operating in a normally aspirated condition so disconnecting the IMRC will hurt drivability a bit. ThinJim and Hemhaw actually demonstrated that there's a loss of WHP with the IMRC disconnected. There's value having the IMRC connected if your tune can tollerate it. Disconnecting the IMRC is a bandaid to prevent detonation. If you've got to choose between detonation or disconnecting the IMRC - disconnect the IMRC. If you can keep the IMRC without getting detonation, you'll see the most benefit.
#47
Blown is Best
https://acurazine.com/forums/2g-cl-dynograph-gallery-51/hbp-emanage-489188/
I'm in Kalifornia running 91 octane fuel. Had my car smog checked for the first time 6 months ago and it passed fine in it's current configuration with the Greddy in place.
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
2003, acura, back, cl, comptech, disconnect, gm, imrc, install, piggy, sc, supercharger, synchromesh, tl, tsx
