What grade of gasoline do u feed your cls??
Old 10-08-2003, 09:43 AM
Powered By HONDA
Type S's Avatar
when i lived in seattle..i feed it grade 92 which is the highest u can get.and now i move to fl state..i feed it 93 which is the highest u can get..
how about u guys?
one more question..
my dealer told me that i just need to feed my new element 87 grade of gasoline... and that is what i heard too from element forum:o
grade 87 gasoline for 2.4 Liter DOHC VTEC engine?
just need commends from u guys
Old 10-08-2003, 09:45 AM
Administrator Alumnus
Scrib's Avatar
Mobile 93
Old 10-08-2003, 09:46 AM
Moderator Alumnus
mantis23's Avatar
generally 93... occassionally 91.
Old 10-08-2003, 09:48 AM
mattg's Avatar
chevron supreme unleaded. i think it's 92 here.
Old 10-08-2003, 09:49 AM
Homeless
chef chris's Avatar
Sunoco 94...only.
Old 10-08-2003, 09:51 AM
Doin' da crack shuffle
Red-CL's Avatar
Sunoco 94 (92 occasionally)
Old 10-08-2003, 09:55 AM
I hate the Mets
mc222's Avatar
Sunoco 93...Every couple tanks 94, depends on the price
Old 10-08-2003, 09:58 AM
Chaptorial's Avatar
Anywhere from 91-94.
Old 10-08-2003, 09:59 AM
Kabachitare!
kansaiwalker1's Avatar
Chevron Supreme, 91 I think. The highest I can find in this area.
Old 10-08-2003, 10:01 AM
dgracer's Avatar
We can only get 91 in CA. I got cheap and put 89 in it when gas was over $2.00 (I know, it only saves $2.00 per tank) and it runs the same in normal to mildly spirited driving. I suspect that it may have slightly less power at full throttle, but no pinging.
Old 10-08-2003, 10:02 AM
I now drive an accord....
spdy0001's Avatar
92 or 93 depending where im at, but I always get the highest possible
Old 10-08-2003, 10:11 AM
Peace. I'm out.
sorty's Avatar
Always the highest possible 93-94.
Old 10-08-2003, 10:30 AM
fuzzy02CLS's Avatar
93 nothing less. Any real difference with 94?
Old 10-08-2003, 10:32 AM
Sly Raskal's Avatar
i've only seen 91 & 92 available in cali, i wish we had 93 & 94
but i feed mine 91 but preferably higher if i can find it.
unixadm's Avatar
93 Most of the time (usually Mobil or Amoco, now BP)......94 if I happen to be at a Sunoco.
Once local Sunoco has 100 Octane racing fuel. I had put it in my Audi A6 a few times, but that was when gas was cheap (94 was $1.20-$1.30.....the 100 was $2.49......now the 100 is around $5/gallon!)
Old 10-08-2003, 10:50 AM
One who Laps
sonor kid's Avatar
93 octane only.
Old 10-08-2003, 10:52 AM
Cost Drivers!!!!
Zapata's Avatar
amoco, hess, mobil, exxon 93
Old 10-08-2003, 10:53 AM
Bagged hybrid
BoostedM3's Avatar
91 in cali
Old 10-08-2003, 11:00 AM
mattg's Avatar
you guys that can get 94.
Old 10-08-2003, 11:02 AM
allmotor_2000's Avatar
Damn cheapo 91 octane... that's all we get around here!!
Old 10-08-2003, 11:14 AM
VOTE OUT THE BUSH REGIME
AK_MOBBER's Avatar
diesel will do fine...
Old 10-08-2003, 11:23 AM
Houses Won't Depreciate?
zamo's Avatar
yeah right. Let me know about your injectors after that
Old 10-08-2003, 11:24 AM
zamo's Avatar
Back home, only 84 leaded and Diesel are available in rural areas.
Old 10-08-2003, 11:28 AM
Masshole
tmk70's Avatar
I always use 93 Octane in every car.
Old 10-08-2003, 11:31 AM
noodles tastes good.
n00dleboy's Avatar
hahhaha in Canada you can get 94 all over the place!!!!
I use 94 most of the times and when it's pricey i put in 91.
Old 10-08-2003, 11:42 AM
///M POWER
darrinb's Avatar
94 sunoco or 93 amoco
once i put 110 and it fawked my car up bad
///M POWER
darrinb's Avatar
fawk u to biatch
Old 10-08-2003, 12:08 PM
Ricky: Drugs > Football
2001CL's Avatar
93 and 91 i just get the highest.
Old 10-08-2003, 12:16 PM
A-CL Senior Member
riceburner503's Avatar
All of the cali guys can only get up to 91!
Old 10-08-2003, 12:46 PM
Floyd Mayweather Jr.
Black CL-S 4-Life's Avatar
93 Exxon
Old 10-08-2003, 01:08 PM
LvMyCL23's Avatar
High octane gas is for high compression and forced induction. All high octane gas does is make it so that the gas combusts at the very top of the chamber. High octane gas is to prevent premature combustion due to the high temperatures in the chamber. I use the premium because it gets better gas mileage and is cleaner burning. However, it is not necessary. The difference in power that you can 'feel' is really all in our minds. I’m switching to mid grade. In actuality i should be using 87, because that’s what the book calls for. Acura’s like the nsx, mdx, and the second gen cl, to name a few, require 92 or higher it says so in the manual. Putting higher octane in say a first gen cl that is normally aspirating will not gain any more power, in fact too high octane can cause the gas not to combust at the right time and throw off the internal combustion causing the car to drive hard and even possibly bend or break a piston or valve. so in other words use what the book calls for, the guys in japan know what they're talking about.. they made the car.
Old 10-08-2003, 01:34 PM
jrudd's Avatar
93 in Arlington, TX
Old 10-08-2003, 03:06 PM
If using lower-octane fuel causes detonation... the knock sensor will retard timing and yes... you will lose power.
Old 10-08-2003, 05:50 PM
GoldieAlek's Avatar
93 @ Shell
Old 10-08-2003, 05:52 PM
DRM600's Avatar
Originally posted by chris3240929
Sunoco 94...only.
Old 10-08-2003, 06:41 PM
Subie Dubie
Red Rider's Avatar
Now that we got rid of Gay Davis, maybe Ahnie will give us back our 92 octane I'm sure that's what he'd like in the Hummer !
Old 10-08-2003, 07:25 PM
///M POWER
darrinb's Avatar
i'm sure your blower would love to get some 93 octane and that high boost pulley
Old 10-08-2003, 09:30 PM
DC Cruiser
greyjhu's Avatar
Costco 91 @ $1.659 (last fill), and when it gets about half or near half fill it with 87 depending upon price-
Old 10-08-2003, 09:53 PM
What, me drive fast?
blackmagiCL_S's Avatar
Very simple...if your Element says to feed it 89 then feed it 89.
I give my car premium to get the "performace" that is promised. MY Civic wanted @ss gas...89. THe Prelude needed 93 to get it's 200hp (stock).....I believe that the CL drives better on sweet gas. The Element must be made to play on cheap...89oct...feed it what the book says...
Old 10-08-2003, 11:37 PM
2004 Euro Cup Champions
dets's Avatar
91+ . at my gas station they sell 100 also. 4.50 a gal.
Quick Reply: What grade of gasoline do u feed your cls??
