What exactly is vtec and what does it do? Stupid question...I know
I understand that Vtec kicks in around 5000rpm on our cars. What exactly does it do to produce more power(puts on flamesuite)? I can definately feel and hear a difference when it hits vtec...almost is like a supercharger.
What is vtec?
What does it do?
I tried doing a little research on my own, but quickly got confused b/c there seems to be a bunch of different types of "vtec" engines...DOHC, SOHC, i Vtec, iVtec I, etc
What is vtec?
What does it do?
http://www.youtube.com/watch?v=_YRM_gD_tkQ
has to do with cams i believe; essentially they all work as apposed to working individually...hence the louder "roar"
sorry...i'm not quite too sure how to explain it either...just think "unison" haha...
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Bye Bye CL!!!
Variable timing and lift electronic control ... toyota (vvti), nissan, etc. all have there version of it. purpose: for greater fuel efficiency at lower rpm's at the sacrafice of power. Vtec = greater Lift and duration of intake and exhaust valves and that = more power.... to keep it short and simple.
Bye Bye CL!!!
This might help... educate yourself
... lol just kidding bro, but this should help
http://www.nsxprime.com/FAQ/Technical/VTEC.htm
![n00b](https://acurazine.com/forums/images/smilies/n00b.gif)
I'll take a stab...
The cams have a bigger lobe (sp} for VTEC and some sort of hydraulic valve engages to run on the more aggressive lobe opening the intake/exhaust valves higher/longer to create more air entering and exiting the engine.
u definately notice it on the CL type S when it kicks in
in my j30 u feel a deep tone change and off corse the acceleration..its fun...u floor it and it goes slow then all of a sudden booooom ,''houston we have launch,space shuttle CL is now in orbit''
Bye Bye CL!!!
Originally Posted by GreenMonster
Nice link ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Thanks green, informative and accurate. I was too lazy to type in depth a complete explaination
Originally Posted by 03CLSMT
I'll take a stab...
Older TLs and Legends have VIS (Variable Induction System)
Additional butterly valve opens at around 4500 rpm's to increase airflow.
Originally Posted by Seattle_03CL-S
only in first gear for me =[ hopefully it will change when i get my intake, summers here and im ready for my mods =]
Let me throw in my
In the "cam" world you basically have two types. You have one thats made for Low to Mid RPM power, and one thats made for Mid to High RPM power.
Vetec kinda incorporates the best of both worlds. Two cams in one!
In older cars like mucsle cars, you had to decide low end grunt, or high top end power. If you had one you did not usually have the other. There was always a trade off. A Sacrifice if you will. V tec just adresses that problem.
I know ther is more than that, but for simplicity this is what I'm trying to convey to him.
Hope that kinda helps ya a little bit too.
Originally Posted by CH46ESeaKnight
Wow in my 01, CLS i feel it in every gear, not only feel it but hear it big time. You might want to check it out. There might be something wrong. ![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
IBankMouse
06-13-2020 12:53 PM
SinCityTLX
10-07-2015 01:24 PM
