what does a CAPACITOR do??
Old Sep 2, 2001 | 06:04 PM
Crazy Bimmer's Avatar
I have no idea what they are used for... like this thing, its used for car stereos but i dunno what they do..
Old Sep 2, 2001 | 06:25 PM
autoxCLS's Avatar
An amplifier uses a greater amount of voltage as the sound levels increase. Voltage is, by definition, the difference in potential energy measured between two locations.
So, a capacitor is a short-term "battery" that stores energy for when the amp's voltage and amperage needs are greater than what the car's electrical system can provide.
In this case, the "cap", as it's commonly referred to, lets your amp hit high notes and deep base without dimming your car's lights, or anything else like that.
Old Sep 2, 2001 | 06:27 PM
would this also solve the problem if the amp cuts out a litle at high volume?
Old Sep 2, 2001 | 06:28 PM
mdaniel's Avatar
Capacitors are like small batteries. Ever unplug a radio from the wall and have it still play for couple of seonds? That's because the power supply charges the capacitors and the capacitors actually power the radio. When your stereo thumps, it pulls more juice than your car's electrical system can pump out. The capacitors can react faster so they make up the difference.
Old Sep 2, 2001 | 06:29 PM
autoxCLS's Avatar
Depends... an amp can "clip" at high volumes if the amp is a piece of crap. If the whole range of music "dims" then you might need a capacitor. However, if only the high notes "clip", you might need another amp or better speakers... I'm not a stereo expert, so I can't say.
Originally posted by AcurA CrazY:
<STRONG>would this also solve the problem if the amp cuts out a litle at high volume?</STRONG>
Old Sep 2, 2001 | 06:48 PM
Satin Slayer's Avatar
aka gimmesomesugar
The "flux" capacitor allows you to travel in time
Old Sep 2, 2001 | 06:59 PM
Sypher's Avatar
Darth Chocolate
Originally posted by Satin Slayer:
<STRONG>The "flux" capacitor allows you to travel in time </STRONG>
As long as you have 1.21 gigawatts of power!
Old Sep 2, 2001 | 07:03 PM
autoxCLS's Avatar
Way to hijack a thread.
Well, this WAS productive.
Old Sep 3, 2001 | 01:46 AM
EricL's Avatar
<STRONG>I have no idea what they are used for... like this thing, its used for car stereos but i dunno what they do..
</STRONG>
AS everyone pointed out it is a energy storage device. The big ones are in the 1-farad range (or more). Its effectiveness can be huge if the wires getting to the amplifiers in the "back" of the car are a bit small (with some caveats). There is also the matter of different batteries -- different ones have different internal impedances and this has some bearing on "all of this".
For example, if you had a "perfect" battery, in the trunk feeding the amps, you could get away NOT using a big cap for "reserve" energy/peak energy needs. (I haven't seen a perfect battery yet -- they all have some amount of internal resistance that limits peak current flow.) One other topic that is not addressed is “some” batteries have internal noise mechanism that the capacitor will help to eliminate – with newer amps, this is not such an issue (for technical reasons).
However, in a lot of situations, a typical car with a BIG stereo (big hungry power amps) will need to be supplied with reserve (current) that the BIG cap (as pictured) supplied.
So, I know some of this sounds like techno-babble", but in the "right" circumstances, it will really help out with high power transients...
(It depends -- I will say that it probably wouldn't hurt...)
IMO -- if you like drums and "percussive" sounds at high volumes, it couldn't hurt...
Old Sep 3, 2001 | 02:36 AM
SilverKnight's Avatar
Retired. Not available.
Umm ... I think this is an amp related problem. I never had anything like this happened to me.
Regarding the cap., with 150Amp stock alternator, I dont think you would need a cap unless you have an 250watt (or higher) rms amp running at full load with all lights and accesories turned on.
Old Sep 3, 2001 | 02:38 AM
RedLineTypeS
Guest
Posts: n/a
</STRONG>
Uhhmm it takes the voltage created by your alternator and transforms it to 1.1 gigawatts then sends you bak to the future !!!
Old Sep 3, 2001 | 08:41 AM
Chris's Avatar
- daemonichris -
i thought i was the only one that didn't know what it was.
Old Sep 3, 2001 | 05:24 PM
Originally posted by Chris:
<STRONG>i thought i was the only one that didn't know what it was. </STRONG>
hahah yea i was scared to ask, but i figure why not.
Old Sep 4, 2001 | 05:01 AM
Akim711's Avatar
dynamic Duo!
flux capacitors? haha, and i thought these replies would be from highly skilled electrical engineers or something. heh
yeah, you wouldn't need a cap unless your amp(s) are drawing too much current from the battery/alternator. The consequences from an amplifier sucking too much current would be like instrument panels and headlights dimming at random frequencies during music play. If this happens, a capacitor would be the solution.
Yes, you can think of it as a (very temporary) battery that drains by the millisecond. When you turn your car on, it would charge up again (called DC steady state) and kick in every time your alternator or battery can't provide the juice, so it can focus on headlights and other things. Installing one isn't hard either... just make sure its wired in parallel with your amps.
Old Sep 10, 2001 | 01:10 PM
bone_stock's Avatar
Ever wonder how an airbag deploys in a frontal impact when the battery is crushed? Capacitors!
VeeralS05
Mar 6, 2006 03:21 PM
Zasker1
Feb 26, 2006 10:04 AM
fizzle
Mar 4, 2004 05:12 PM
calvinpham
Jul 20, 2003 12:47 PM
guji2
Dec 9, 2002 12:31 AM
