What are CV joints and why would they wear faster with modded suspension?
CV joints are inside the rubber boots that are attached to each side of your axle. They tend to wear out a little quicker on cars that are lowered because they're constantly running at an angle where the boot has a little stress on it. Usually CV joints last a LONG time, however, CV BOOTS tend to tear. If you drive around on a torn CV boot all the grease gets out and your CV joint goes bad. Ever hear cars that make a ticking noise when they turn? That means that have bad CV joints. I've already replaced on CV boot and I'm only at 23k miles....however, I've had a few drives with my car just skimming off the ground by about 1/2 inche, so that probably did mine it. It took 2 hours and $30 to fix. Hope that info helps.
-Aaron
-Aaron
I think mine are starting to go.. i feel this mini bump sensation on my gas pedal..like thud thud thud.. when ever im travelling at low speeds.. at high speeds its gone...when im slowing down to a stop ..it returns... its pissing me off.. any ideas guys??!?..
Originally posted by CO-CL-S
I'd check other things like tires first.. If it's only when brakes are used it could also be warped rotors. YMMV
SinCityTLX
20
10-19-2015 11:23 AM
SinCityTLX
10-07-2015 01:24 PM
