what to check?
Old Dec 27, 2008 | 12:42 PM
combat mediC's Avatar
what to check?
Hey guys, I just got back from a 2300 mile roundtrip roadtrip. The cl made it good, no problems, however shes jerking as I brake now, any ideas? (rotors were re surfaced last year and new pads last year). What all do you check after a road trip?
Tires, belts and fluids? or do you go deeper and check suspension and stuff? Just curious
Old Dec 27, 2008 | 01:30 PM
poisx7's Avatar
its shud be fine.
maybe the rotors a wraped, a common problem of the cl.
i resurfaced mine 2x and guess what they are still warped today.......
so, i drive it like that.
some pads might be worn dwn more than others a frozen or stuck caliper problem, This happened to mine, I unstuck it and it felt ok for a while but ............ back to its old ways...........
I also once disconnected the ABS when i was putting in the side mounts and it drove great without ABS 4 three days.
so i came to the conclusion that it was the ABS that was messing up.(maybe i needed a brake flush)
Old Dec 27, 2008 | 07:47 PM
Thanks pois, I'll do that as well, (disconnect the abs) she needs an overhaul anyway. lol cant hurt
Old Dec 27, 2008 | 11:35 PM
fuzzy02CLS's Avatar
Check your brake fluid. Then I would say your rotors are warped again. Rotors will warp more on long HW trips.
I've had it happen in other cars. I used to do 2500 miles trips 10 times a year or more.
Mike Pilipenko
Mar 26, 2024 09:21 PM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
hrothgar02
Sep 28, 2015 11:08 AM
mars
Sep 28, 2015 11:03 AM
