What is the best header to get for the type-s?
10x30 is fine, 10x40 bolts will also work but will stick out about 1/2" further past the flange but might be easier to torque down if you're under the car and installing them yourself. Just make sure the pitch of the bolts match the nuts.
Trolling Canuckistan
Originally Posted by AARONSredTYPE-S
U THA MAN..LOL..YEAH, I KNOW ALL THE FACTS AND ADVANTAGES, BUT I CANT REALLY FIND A PRICE OF COATING
ANYWAYS, WHAT SIZE ARE THEM BOLTS 10X30 OR 10X40? DOES IT MATTER? IM FLIPPIN READY FOR THE 20+ HP!
ANYWAYS, WHAT SIZE ARE THEM BOLTS 10X30 OR 10X40? DOES IT MATTER? IM FLIPPIN READY FOR THE 20+ HP!I did some searching, but couldn't find the thread. He had pics in there as well.
hey
ok so i have megan racing and they are good but make weird buzzing noises from the welds on the inside of the pipes. it sounds close to a turbo but sometimes annoying. from what i have learned xs is the best for your money. dont get obx because they always place there holes for the o2 sensor in the wrong place. comptech iss the best but is also wayy more money.
Originally Posted by Nate@Comptech
I won't comment on who has the best header.
But for everyone's information, our model just dropped $100 to $1149MSRP.
-Nate
-Nate
Originally Posted by black label
Ceramic coating and wrap are essentially for the same thing, keeping the pipes hot so the exhaust stays hot (the hotter the gas the less dense it is and the faster it can flow).
Ceramics is probably the more high tech way to go (I haven't seen an F1 car with wrapped headers in a long time, they use ceramics) but it will probably be more expensive. The other issue with ceramic coating is that it will do little to nothing in terms of sound deadening.
Hey, that was my 500th post, lets party
Comptechs are the way to go imho, although they are expensive. I've had XS and they didn't work out, had leaks and hissing from the flex pipe. Wrapping them with adhesive exhaust wrap didn't help and wrapping it with cloth exhaust wrap didn't do much good either. Ever since I put the Comptech's on, I've had zero problems, and when taking the XS headers off and comparing them to Comptech's, I noticed the bore of both XS headers were smaller than the bore of the Comptech headers. I have a pic somewhere that I'd have to dig up. To each his own though, it looks like the quality of the XS headers is getting better which is a great thing.
i am ordering my xs or ss autochrome headers in the next few weeks i cant justify spending 1149 for headers when you can have ceramic coated xs headers and new hardware and gaskets for half the price or less.
Originally Posted by CL-Future
Coating is actually done to REDUCE heat, not keep the pipes hotter. That's why it helps your engine bay by producing less heat from the headers, thus having less of an effect on other parts that may be affected performance wise in the engine bay. The outside and inside of the pipes are coated to allow the hot exhaust to escape faster which helps prevent heatsoak from occuring.
The wrap keeps my engine bay cooler by keeping the heat in the pipes. I believe the ceramic coating does the same thing, it insulates the pipe so the heat isn't released into the engine bay.
OK-regarding the primary tube "bore "( actually diameter) - 1 5/8 is plenty large for a 3.0-3.5 displacement v6( and small v8) so going larger than that will shift torque curve to mid to upper rpms. smaller primary tubing( but definitely larger than factory restrictive port size) will aid scavenging, and help with breathing and give a broader torque curve- meaning more of it available at wider range of rpms, instead of just high rpm. also- keep in mind the collector where these pipes merge, if these are too large- the problem is compounded. So the ideal layout isnt just size, but flow, velocity, fit, and the merging of the pipes. So, the Xsp, Jvt and others should emulate the best brand in design, BUT affordable like Xsp, Jvt, megans etc. Seems like Xsp are proving to be a steal- but Jvt yet to show it's superiority(if at all.)
Bringing this one back from the dead. Price aside, how do the DC Sport headers compare to the XS Power? I don't think I can justify the money for new Comp Techs, so it is between these two companies.
Thanks,
Sean
Thanks,
Sean
I have seen that too, but like someone in this thread said you can buy them 11 times before you have got to the cost of the Comp Techs. I would LOVE to have the Comp Techs, but not for that price. So that leaves DC (not thrilled that they are not stainless) or the XS Power (not thrilled that they are XS).
Sean
Sean
i think picking headers for auto is easy, get the dc unless you really want comptech. For the manual it is a harder decision since its either 1100 headers or 100 headers. For manual i would suggest used ct.
yea they dont make xs anymore. ive had mine for years with no problems. best $100 i ever spent. the only thing ive had to do to them was to get the bottom of them welded. i scrapped a hole in the header because my car is so low lol.
when i threw my CT's on the motor noise wasn't even louder than the stock oem exhaust. mine you i did wrap them in dei header wrap but still I was impressed regardless. i didn't pay the 11-1200 tho... got them for under 5.
over a grand is just too much i think for one mod.... aside from rims and exhaust system.
but that's just me
but that's just me
but that's just me
but that's just me
DC sports or CT for known headers Mugen makes some as well and they are under $300
http://www.jdmhub.com/index.php?rout...67_25442_60673
)It looks like I will go with the Megan, at least try them out. I really hate the crappy ceramic coating on DC headers, and I don't want to pay to have them re coated. If they made them in stainless Id be all over them. When I get them I will let everyone know how they are.
Sean
Little bump on this thread as I had to do a little work onthe XS headers yesterday. I was getting an annoying buzz between 2700 and 3000 RPMS from the flex pipe as my exhaust wrap had worn away (it lasted almost 3 years in New England weather). While I was under the car the only issue I saw was a bit of rust on the exhaust hanger. Other than that, no signs of cracks or any other issue. At this point for the $97 I spent on them, I certainly can't complain.
BTW, the re wrap of the flex pipe took care of the buzz 100%.
bringing my 4 year old thread back to life.
After researching, if nobody has ct or xs headers on the black market, I am buying
JVT headers for an automatic, and getting them rewelded to fit my 6spd...
Yeah, no kidding when I saw that I was like "NO way is anything Mugen under 300 bucks
Sean
Sean
is it just an aesthetics thing? Or are you saying it doesn't do what it's supposed to?
I just wanted to state that Ive had my XS headers on my car for 5 years now without any problems. I do recommend getting new bolts and gaskets though. BTW-I have a CLS with a 6speed. I even posted my dyno sheet after i installed the headers and AEM intake.
And where can you purchase a set of XS headers new right now? I sold mine a couple years ago for 3x retail shortly after they stopped selling them. They've been unavailable for almost 3 years now.
