Weird ticking noise from my beloved 6sp...any ideas?
"tick" is the best I can do on explaining the noise-id say ping but I know Id just get a shitload of piston/tranny/heads related answers.
anyway, it only happens(so far as I can tell) in gears 1-4. it occurs right after I shift and release the clutch...but not always. sometimes it wont happen at that moment and instead it will happen after I let off the gas for the first time after shifting. the clutch is grabbing as good as they do
and my acceleration and overall power don't seem to be affected.
If anyone knows anything on this matter, pass it on. If a better description is needed please let me know. thanks
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
not sure if its the solenoid
I looked into the purge threads and I wish I had when I had my TL; (thanks Dru, you might be right)I remember THAT noise but I don't think its the same as what I'm currently hating. The noise I hear is NOT the continuous tick that the solenoid problem is famous for. This noise, while similar in sound, only happens right after releasing the clutch or when I first start to decelerate. In either situation, it only ticks once until either situation is recreated. SO I ask again, specifically to the 6speeders, what the hells going on with my damn car?????
Originally Posted by Elijah J
I looked into the purge threads and I wish I had when I had my TL; I remember THAT noise but I don't think its the same as what I'm currently hating. The noise I hear is NOT the continuous tick that the solenoid problem is famous for. This noise, while similar in sound, only happens right after releasing the clutch or when I first start to decelerate. In either situation, it only ticks once until either situation is recreated. SO I ask again, specifically to the 6speeders, what the hells going on with my damn car?????
Originally Posted by ljmushock
I had the exact same problem w/my 6-spd... It took the dealer 3 visits to find the problem, and at first they couldn't duplicate the sound (idiots)... Anyway, turned out it was my left front wheel bearing... They also had to re-torque all the drive axles/control arms/sub frames. It could have been any of those things. Should still be covered under warranty if you have one.
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Originally Posted by CL FWD SPEED
how much a pair of CV joints costs?
If you hear the clicking noise when your going around turns then it's def the CV axles, but I'd think w/only 75k miles that they wouldn't fail that quickly... It's almost certainly some component w/your drivetrain/front suspension. Like I said in my last post it took Acura 3 times to find the problem and even then they just fixed/checked several diff things at once so I never really new exactly where the noise came from.
Personally, I'm tired of my ENGINE TICK!!!!! tic tick tick tic tic tic tick tic tick tick is getting so annoying.... well guess it's time for the valves clearance to be checked.
Good luck man, hope it fixes easy, 6 spds kick ass
thanks bro. but I hope the info wasnt based on a ticktickticktickticktick bc it really is only a tick.....(shift)..(+- a few...) tick. lol thanks again for the info
Bye Bye CL!!!
Originally Posted by fuzzy02CLS
You may want to check your cat heat shield. May be loose & hitting something slightly. Could be that simple.
I'm with fuzzy, I have almost the same problem but only at low rpm when i'm accelerating I here it sort of tick and it sounds like it's coming from that area, but I also know I need new motor mounts :
well, Im taking the beast in to Acura on Sat so we'll see. I read some of the motor mount saga and while I didn't read all of it I heard no mention of this problem. Have I just not read up that point or is not associated with that discussion? ... yeah, laziness on my part I know.
I recreated the noise for the dealership's service manager who had never encountered it before. She recreated it for their lead mechanic. They ended up tracing it back to the brakes...saying the after market rotors and pads created a gap of some sort (rotors are in good shape and pads still have over 50%). Originally it was supposed to cost 60 but they ended up not charging me for it. I was told the problem could probably be fixed with some sort of shim for 120. apparently they would have to take off the pads and rotors to do it. has anyone ever heard of this happening with with am brakes?????
Never heard of it. What brand rotors & pads?
Originally Posted by LukeaTron
There are supposed to be shims between the pads and caliper piston. If they're not there, the brakes make noise. To put them in the rotors don't need to come off but the pads do.
I have a funny feeling it may actually be the differential making this noise especially since it seems to be apparent only when applying torque to the front wheels... its a clicking that seems most noticable as the next gear is engaging and the tires are applying grip. it only lasts a split second.
A bad wheel bearing could be the cause. That comes from the hub area & could be taken for a brake related noise.
Love the car, hate the noises!
Seems like a few others are experiencing similar problems. Just wanted to try and get this thread moving again. I really don't think its the brakes but I would like to know if anyone else has installed AM rotors and pads without the "shims" and what their experiences have been.
between mods and maintenance it's never ending.
here's a link to another thread discussing a similar problem.https://acurazine.com/forums/showthread.php?t=196729
I may try the "white lithium grease" today and see if it helps. If anyone else has made any headway with this oh-so annoying problem PLEASE POST!!!!!!!!!!!!!!
^ i have a constant rubbing/ ticking noise while i drive after install of new rotors and brake pads this weekend. i used lithium grease to help, still there. no noise when i bake though. i think it might be my axles? or wheel bearing, im gonna see if a tech will check it out for free ill let u know
joflewbyu2
10-08-2015 11:16 AM
4drviper
09-23-2015 09:00 PM
