Weird issue
3 the Hard Way
Weird issue
Now before y'all get all crazy, realize I don't know much about mechanics, but I'm trying to learn.
If I floor it, then let off the gas completely, it doesn't decelerate smoothly. The RPM drops in like steps, and the car slightly jerks with each drop. My old 95 corolla never did that. I don't know if that's an Acura thing, a CL thing, or hopefully not a sign of a failing transmission. I don't notice any of the other tell-tale signs of a failing transmission, but I clueless as to why this happens
1 Post
if you are at redline and let off the gas completely the automatic will shuift harder than if you were just cruising. It's probably just the transmission shifting up the gears. That's why when I go WOT from a stop I don't just l;et off the gas completely when I'm done, I just give it a little throttle to keep the shifts smooth.
GEEZER
WOT=Wide open Throttle.
