we should ask hondata...
how many tl-s/ cl-s ecu's they would need to flash to make it worth their while.
i think there would be a lot of interested folks between us, a-tl and a-world.
let's do eet!
let's do eet!
i emailed them sales@hondata.com
here www.hondata.com
Do you guys think there is really much room for improvement? As far as i know hondata doesn't do anything that couldn't also be adjusted with an v-afc, air/fuel, vtech points, ignition timing. I know people who have used afcs hadn't had much success. I believe one of the other tricks is making the i-vtec setup more aggresive which is a moot point.
it wouldnt be high at all for a 10-15 but more likely a 20-25+hp gain top to bottom...however our ECU' sare NOT flashable...im hoping the new TL's are then youre talking 800 for the ECU and 500+ for the flash...still worth it IMO
Originally posted by bnavarro
i think AEM makes a computer for us.
there are no pre made fuel maps, timing curves etc. for our cars.
When I ordered my 03 Accord V6 I sent an email to Hondata. The response I recieved was that they were not currently working or even planning on working on anything J-series related.
I am not sure about the J32's but the J30a4 in my car is now running a MAF sensor instead of the traditional honda Speed Density setup, the ecu's are also much different than the K-series engines.
I was a little angry, but then again our J-series motors are reletively strong to begin with.
Dustin
Dustin
reply from hondata -
The problem is that the ecu is not reflashable on these cars. Perhaps we will find something in the future to do to these ecus, but not anything at this time.
Hondata Inc
2341 W. 205th St. Suite 106
Torrance, CA 90501
310.782.8278
310.782.6383 FAX
http://www.hondata.com
Hondata Inc
Torrance, CA 90501
310.782.8278
310.782.6383 FAX
their reply -
These will not work very well on a v6, as the intake manifold will be slightly displaced by the thickness of the gasket. We have no plans to produce these gaskets.
Hondata Inc
Torrance, CA 90501
310.782.8278
310.782.6383 FAX
Hondata Inc
Torrance, CA 90501
310.782.8278
310.782.6383 FAX
CL's do not use reprogrammable ecu's .This technology started on the new RSX .AEM's programmable ecu may be the way to go for those inclined to try this out but you will have to contact them to see if there is a version for the CL .I have seen these ECU's and from what I saw they are not meant for the CL .They seem to be about 1000 dollars in cost and a laptop PC is helpful for tuning purposes .Jens
Matt do your centerlines rub at all on your ride? Thinking about picking up a set for my tsx. Sorry for the OT.
I'll bring it back on topic by askign what kind of gains you guys get with a tuned v-afc? If i remember it isn't much....
it barely rubs every once in a while. usually just the front when angling in a driveway with the wheels turned while hitting a bump.
it has never even rubbed hard enough to scuff the tires, and thats w/ ~ 3" drop.
about the v-afc. there are a few people who have them, the gains seem minimal. johntypes has it along w/ all the mods i have plus more. and i've still run a 1/10th faster in the quarter.
I WANT A SOLID 13 SEC. ALL MOTOR CL-S, DAMMIT :swear2:
Originally posted by RUF87
Let's say that the new CL/TL TypeS comes with a programable ECU. What are the chances that it would be backward compatible with our cars?
Ruf
Ruf
The AEM ECU is generic... they probably don't have the adaptor-kit wired for the CL-S, but you can do that manually (wiring-harness adapter is available). However, extensive tuning on the dyno is needed. Unless your car is a race-car... its not worth it for the 5-10 extra hp. For a built F/I car... its worth it, I suppose!
Wisc Badger
492
Nov 5, 2011 10:33 PM
bluesolara
23
Oct 14, 2006 07:45 PM
YBA
Jul 1, 2006 06:07 PM
Scottybue
Jul 15, 2005 11:05 AM
