A way to keep the auto dim mirror off?
Old Jun 14, 2002 | 08:01 AM
omoulton's Avatar
Does anyone know of a way to set the mirror to off when the car starts? The manual indicates this is not tied to memory pf the drivers seat. I turn it off and it's own when I take off again. Thanks.
03' ABP CL-S 6- speed
Old Jun 14, 2002 | 10:31 AM
JRock's Avatar
Old timer
The auto-dim mirror? Uh just push the button on the bottom that turns off the little green light. Then it will be off. It won't come on unless you push the button again.
Old Jun 14, 2002 | 10:33 AM
Loseit's Avatar
Changin bulbs since '73
Old Jun 14, 2002 | 10:56 AM
EricS's Avatar
I believe it will come back on after you start the car again. Could be wrong, haven't played with it much.
Old Jun 14, 2002 | 02:29 PM
omoulton's Avatar
Yeah that switch was throwing me off. The mirror turns on when ever the vehicle is started. I would rather it only come when the on/off button is depressed. So the question should have been is there a way to prevent the mirror from turning on when the car is started??
Old Jun 14, 2002 | 03:04 PM
JasonT's Avatar
Is this a 6 speed/2003 thing? My 2002 stays off unless I press the button. It does not come on when I start the car.
Old Jun 14, 2002 | 03:18 PM
JRock's Avatar
Old timer
Yeah mine stays off too. You guys have some funky rear-view mirror. :P
Old Jun 14, 2002 | 03:28 PM
EricS's Avatar
Prolly got redesigned with the OnStar stuff.
Old Jun 14, 2002 | 03:32 PM
Klamalama's Avatar
Capo di Tutti Capi
Re: A way to keep the auto dim mirror off?
The mirror only operates with the button: Up it's ON; Down it's OFF.
When ON a green LED glows. I leave mine on always.
Old Jun 14, 2002 | 03:33 PM
TakeFlight's Avatar
It definitely must be an '03 thing because my switch is not a "momentary" switch, it's a true on/off switch. If I leave it off, it stays off even when I start the car. If I leave it on, it stays on even when I start the car.
Old Jun 14, 2002 | 03:40 PM
Klamalama's Avatar
Capo di Tutti Capi
It's NOT an 03 thing. Mine is an 03.
Perhaps it's an 03 Navi thing?
Old Jun 14, 2002 | 03:42 PM
EricS's Avatar
Exactly, it's an OnStar thing with the redesigned rear view mirror.
Old Jun 14, 2002 | 06:18 PM
nate'sCLS's Avatar
damn-- that suckx :P
Old Jun 14, 2002 | 08:35 PM
IWannanS's Avatar
'03 with Navi. Mine turns on with the car.
Old Jun 14, 2002 | 10:43 PM
Shawn S's Avatar
Stupid question…..Why do you want it to be OFF ???
Shawn S
Old Jun 14, 2002 | 10:54 PM
nate'sCLS's Avatar
This was probably the thinking as they redesigned it that way.
Old Jun 15, 2002 | 10:44 AM
JasonT's Avatar
I don't need it most times. I have 15% tint on the back. That does fine for me. Sometimes I do use it on road trips. But I keep it off most times to avoid it burning out as others have.
Old Jun 17, 2002 | 08:30 AM
omoulton's Avatar
I have seen posts here regarding the mirror needing to be replaced as the mirror it ceases to operate. There seemed to be a concensus that leaving it off until needed is the best way to aviod the mirror failure. I just forget to turn it off after the car starts. It probably not that big a deal anyway.
Old Jun 17, 2002 | 11:05 AM
Slimey's Avatar
Where is my super sauce?
I leave mine on all the time. I'll let Acura replace it if it poops out (eventually).
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
malvothegreat
Sep 29, 2015 12:38 AM
