Warped Rotor Problem
Old Apr 15, 2003 | 08:30 AM
CLSteve's Avatar
We have an '01 CL and an '01 TL, both with about 25K miles and both with the warped rotor problem mentioned on this Board.
My Questions: Is there an "official" Acura policy regarding how this problem is handled, or is each case dealt with individually? Do they typically replace pads as well as turn the rotors? Anything else I should know before I contact the dealer?
Thanks for your help,
Steve
Old Apr 15, 2003 | 08:54 AM
Bill Faure's Avatar
Yes, ask for TSB017 service. It has been my experience that a rotor truing is useless unless you have the pads that TSB017 calls for. Do a search here for TSB017, or obtain from Acura.
Old Apr 15, 2003 | 08:56 AM
CO-CL-S's Avatar
Re: Warped Rotor Problem
Steve
See TSB 01-017.. Ask Acura for a copy of it, or maybe somebody can post it here..
Old Apr 15, 2003 | 11:21 AM
CLSteve's Avatar
Any input on whether or not Acura will pick up the cost for truing? For pads? Acura customer service says its normal wear and tear, so no $$, but that my dealer may pick it up as "good will". I'd like to know what's going on here before tackling the dealer.
Thanks,
Steve
Old Apr 15, 2003 | 11:57 AM
Shawn S's Avatar
My 2001 CL was fine on its original rotors for the 25,000 that I owned it.
My 2003 is starting to show signs of a warping problems and I haven’t even hit 11,000 yet.
Shawn S
Old Apr 15, 2003 | 01:28 PM
BSK181's Avatar
read the bulletin, it is very specific
they are not doing you a favor replacing pads and truing rotors, they are supposed to if warped
Old Apr 15, 2003 | 10:46 PM
flint's Avatar
It is not normal wear or a "good will" thing with the dealer TSB017 should make the dealers turn the rotors and give you new pads if you have the problem. I didn't know about this and last year my dealer gave me NEW rotors and left the same pads on at no cost. I would make sure you ask for the pads.
Old Apr 16, 2003 | 12:56 AM
lead_sled_dog's Avatar
Back to Four Doors
Steve
At 48,000 miles, I went to the dealer and said that I was experiencing "pulsing" brakes. I mentioned that I understood there was a TSB for the problem. They turned the rotors and replaced the pads for no charge. Politely suggest you have heard that there is a service bulletin out for warped rotors. You should have no problem getting them fixed.
SidhuSaaB
May 30, 2020 12:40 AM
Chojun
Dec 16, 2015 07:12 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Brandle34
Sep 23, 2015 07:20 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
