VSA Bypass resisors?
Old 01-01-2006, 07:03 PM
Chemmech's Avatar
Question VSA Bypass resisors?
Anyone know how to bypass VSA using resistors? I have seen the post before, but I can't find it through the search button. VSA is really starting to annoy me, since I modded the egr pcv systems.
Old 01-01-2006, 09:44 PM
typeR's Avatar
ill talk with you about it tomorrow...its fairly easy...well easy when you got allmotor and scalbert helping you
Old 01-01-2006, 10:18 PM
Chemmech's Avatar
Old 01-01-2006, 11:07 PM
says "hello to my TLX".
Sun Diego CL-S's Avatar
speaking of the devils... it's been awhile since i've seen either of them.
Old 01-02-2006, 05:29 AM
Never had a clean run
rtatsutani's Avatar
Please post, gonna be doing that soon as well. Thanks!
Old 01-09-2006, 06:32 PM
Chemmech's Avatar
^bupmp^
Old 01-09-2006, 06:47 PM
typeR's Avatar
youll make three wires come to gether in the center like the end of a fork with the center being a plain wire ... one resistor will be 3K ohm the 8K if i remember...ill search my PM's and emails to make sure
Old 01-09-2006, 07:05 PM
typeR's Avatar
Originally Posted by allmotor_2000
Hey, so I figured out how to keep the VSA light soff.
You need a 8K resistor and a 2K resistor. The 8K resistor goes between the center pin and gnd. The 2K resistor goes between the center pin and VCC. This is on the sensor.
On the motor-side, just put a 10W 3-ohm resistor between the two pins.
Now... if you do plan on racing... turn the VSA off by pushing the button because I am not sure what happens if the VSA tries to do its thing!
Old 01-09-2006, 07:07 PM
typeR's Avatar
...im sure ...if you get wheel spin w/o hitting the disable...the dash borad will light up and the car will all but stall
Old 01-10-2006, 06:38 PM
Chemmech's Avatar
So the car will stall out if vsa is left on with this mod?
Thanks for the info typeR .
Old 01-10-2006, 06:44 PM
typeR's Avatar
no...the car will almost stall if you hit it hard and spin on the launch w/o hitting the "disable VSA" button....as long as you dont get major wheel spin ...the worst case scenerio is a VSA and ! light that goes out on the next restart
Old 01-10-2006, 06:50 PM
Chemmech's Avatar
Stalls out as in timing or injector pulse width changes?
Would this be dangerous while under boost to loose fuel?
Old 01-10-2006, 07:35 PM
typeR's Avatar
i doubt timing is effected but it does feel like it fuel cuts upon signifigant wheel spin from a standind start ... this is only an issue if you launch hard and dont disable the VSA
Old 01-15-2006, 10:31 PM
shift@8k
shinybluecls's Avatar
so everything i need to buy is a 8k, 2k, and 10watt 3ohm resistor right? I still have no clue what i need to do with them though....haha im so noob
Old 01-15-2006, 10:56 PM
Nyshadow's Avatar
Wouldn't it be easier to just dissconnect the VSA ECU?
Old 01-16-2006, 01:38 PM
shift@8k
anybody?
Old 01-16-2006, 06:01 PM
typeR's Avatar
You could use the 9K and 1K. Essentially that puts the sensor voltage to be 4.5V. The sensor expects ~3.7V... the 8K-2K combo achieves 4V. 4.5V is okay.
Old 01-18-2006, 09:34 AM
typeR's Avatar
http://www.radioshack.com/product/in...entPage=family
Old 01-18-2006, 12:53 PM
allmotor_2000's Avatar
This fix will prevent the light from coming on when the VSA actuator is removed. However I suggest you disable VSA when trying to race.
Old 01-18-2006, 02:45 PM
shift@8k
so i just buy the 3 resistors typer gave links to above?>
Old 01-18-2006, 02:48 PM
typeR's Avatar
i mentioned that above and can attest that the car will still try to stop the wheel spin...im not sure if it fuel cuts ...but when i hit it hard from a dead stop as soon as signifigant wheel spin occurs the car all but stalls and the dash lights up....this is temp as soon as you restart the car all lights are gone...another easy way to do this is just leave the VSA body in the engine bay still connected to its harness...
Old 01-18-2006, 08:10 PM
Chemmech's Avatar
[QUOTE=typeR...another easy way to do this is just leave the VSA body in the engine bay still connected to its harness...[/QUOTE]
That's a good idea. Would cut back on some resistance to air flow too.
Old 01-18-2006, 09:47 PM
typeR's Avatar
[QUOTE=Chemmech]
Originally Posted by typeR...another easy way to do this is just leave the VSA body in the engine bay still connected to its harness...[/QUOTE
isnt that the whole point
Old 01-24-2006, 02:16 PM
MtBikR's Avatar
I am sick of these lights. Is this the easiet way to fix the lights. What would happen if I broke the LEDs behind the symbols?
Old 01-24-2006, 06:26 PM
typeR's Avatar
the easiest way is to leave the VSA connected to its harness and just in the engine bay somewhere out of the way...but this isnt exactly hard...just read allmotors explaintion above
Old 01-24-2006, 09:02 PM
shift@8k
hey typer, can you message me on aim...finally got the resistors. thanks
Old 01-24-2006, 09:15 PM
quicksilver10101's Avatar
what is the reason for disconnecting the vsa?...isnt it disabled as soon as u turn it off?
Old 01-25-2006, 09:56 AM
typeR's Avatar
it's a source of impeded air flow....for those who want to do a P&P throttle body for example.
Old 01-28-2006, 05:54 PM
shift@8k
guys, this might sound noob but when taking off the vsa throttle body, what do i do with the two hoses connected to it? I'm pretty sure I can't just leave them hanging there correct? Thanks guys
Old 03-14-2006, 08:06 PM
rtatsutani's Avatar
No b/c it's coolant and is connected to the engine block.
Old 03-14-2006, 08:19 PM
rtatsutani's Avatar
If we did this, the light would stay on and we wouldn't be able to turn the VSA off/on right?
On a similar note, what if I just removed the VSA unit, I assume the light would stay on but would this cause the same reaction as if the VSA button was not turned off and the unit was removed and resistors were in place? Or would it just act as if the VSA was turned off and cause me to almost die when I burnout? I definitely do not mind the light being on if that was the case and not have to worry about turning it off and on all the time.
Old 03-14-2006, 09:43 PM
CleanCL's Avatar
you will need to use the resistors or else your car will all but stall.
as for the coolant lines. i'm just going to put a hose from the 2 points on the block that they go to. after looking at it more and more, i feel the vsa is a major source of restriction. not only is it blocking flow, but those coolant lines can get pretty hot and heat up the IAT. i have a pre-dyno and will be doing a post dyno as soon as comptech gets me the stuff.
Old 03-14-2006, 10:08 PM
rtatsutani's Avatar
I noticed the same exact thing. Hope the dyno shows something!
Old 03-15-2006, 06:54 AM
dshearon's Avatar
is the point of this mod to have VSA off and also keep the dash light off?
Old 03-15-2006, 10:38 AM
CleanCL's Avatar
the point is the eliminate air intake restriction/temperatures.
Old 03-16-2006, 02:13 AM
rtatsutani's Avatar
FYI
I removed the VSA unit tonight and put a 8" x 3" hose in the gap. I did NOT put the resistors on yet and the car runs OK but not perfect. The VSA and ! lights were both on. I caused wheel spin and it worked OK (held the burnout) again, but not it's usual self. The car feels like the PCV hose is pinched. Just a little sluggish all around. Another thing I noticed was that my fuel pressure was a few PSI lower than usual. Normal is like 37-39 PSI or so, but after doing this, it was all the way down to 34-35 at idle.
Does this give anyone enough information now to explain what the ECU does when the VSA is not connected and resistors not soldered in?
Old 03-16-2006, 10:52 AM
CleanCL's Avatar
it sees the VSA throttle body not functioning so the computer is pulling timing?
Old 11-02-2007, 12:54 AM
Advance
gc86's Avatar
Where exactly are you placing the resistors? a bit confused on how to wire them, also does this need to be done using a soldering iron? the links to radioshack show a different resistor than you mentioned.
Old 11-02-2007, 08:25 AM
CleanCL's Avatar
would anyone be interested in this w/ directions? i could set something up through a vendor here.
Jamus22
06-11-2023 10:08 AM
tsx_boy
12-13-2019 08:33 PM
copmagnet82
4G TL Problems & Fixes
06-29-2016 08:09 AM
polish_pat
09-30-2015 12:22 PM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
Quick Reply: VSA Bypass resisors?
