vibration question
Old Sep 18, 2009 | 12:20 PM
p.diddy's Avatar
vibration question
would a broken motor or tranny mount cause heavy vibration upon hard acceleration?
Old Sep 18, 2009 | 05:05 PM
RUF87's Avatar
Lead Footed
it could . . . I'm actually dealing with a strange intermittent vibration under acceleration. It's weird as it doesn't do it all the time . . . the first time it happened I thought I had bent axles or something as I had a major dooh moment and hit a big ass speed bump . . . if I figure anything out I'll let you know.
Ruf
Old Sep 18, 2009 | 07:39 PM
phee's Avatar
I got the Shifts
oh wait....
diddy!!!!
its your axles. does it only happen when ur on the gas? does it stop when u let off the gas?
if thats the case, your inner axle is broken
Old Sep 20, 2009 | 12:52 AM
MIKE8898's Avatar
Bonki Ehrite!
the broken motor mount causes a lurch especially when the car is shifting or on hard acceleration
Old Sep 20, 2009 | 01:02 AM
TypeStylinOnU's Avatar
dont be mad
do u have hub rings for your new wheels?
Old Sep 20, 2009 | 09:10 AM
p.diddy's Avatar
no. but i know thats not it.
Old Sep 20, 2009 | 09:30 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
Originally Posted by phee
oh wait....
diddy!!!!
^this is most likely your problem
My inner axle joint failed a little while back and it only had 5000 miles on it ,so it got replaced for free under warranty.
When I started having the problem it started mildly at 35mph and up.As the problem got worse it started at 20mph and started feeling like wheel hop.It took about 2 weeks to get badand once it was I did'nt even want to drive the car calling it a pos. Before this I replaced everything thing related to steering and suspension in the front to set up the car for reliability and to work out a shake when I bought the car. I could'nt beleive it.
But its a easyfix. Pull the inner axle joint cover to veiw inside on the vibrating side and you will probally see it's falling apart.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
joflewbyu2
Oct 8, 2015 11:16 AM
navtool.com
Sep 25, 2015 05:15 PM
