Velocity Stacks
Velocity Stacks
This was posted within another thread, but since it was't directly related I decided to post it separately.
For those that don't know what a velocity stack is or does, here's a few links and some info to help you understand how it can add more power. And best of all, it's a fairly cheap mod.
Velocity stack is not a spacer, but an airflow inhancer that can be attached at various points along the intake system. In the case of the example of the one in the URL below the filter installs over it.
http://www.inlinefour.com/blvest.html
Note, the Comptech Icebox uses this same approach. In my case, not only do I have the CT Icebox, but I've attached a 2nd velocity stack to the front of my ram-air set up, which is at the very front of the CT intake system that extends outside the wheel well. I'll post some pictures as soon as I get it fixed. Had a little accident and need to replace the primary CT intake tube. Anyway, I gained almost 2ths at the track with this set up.
Dyno comparison.
http://www.bpinitiatives.com/?gclid=...FQ-bnAodwxsTsw
airflow analysis image.
Ruf
02 WDP TLS Black Interior w/ Black Grill Inserts & Cleared Headlights
**1/4mile 14.46 @96.07MPH - 14.23 corrected (45-70mph test - 3.5 secs)
17x7 Konig Appeals SMF – 16.8lbs each
P225/45ZR-17 Bridgestone RE960 AS - (Falken Ziex ZE-512s for track)
CT Icebox, Custom RamAir, CT Sways & Springs
3nd Gen Innovative Motor Mounts – Front & Side Only
Bored out Intake & TBs, Mugen Cooling Mods & Thermoblok
Ceramic Coated XS Headers & Random-Tech Hiflow CAT
NEO Anti Freeze & 5w-20 oil w/Militec-1
Tranny #3 Installed 11.17.2008
Note: (**before headers, Hi-flow CAT, IMMs, Bored out Intake & TBs)
Dyno comparison.
Ruf
:o . . . I will as soon as I get it back together. I had a little accident and messed up the bottom piece, so there's nothing to see right now. However, if you can mentally picture how the CT Icebox set up looks, the lower intake tube is extended out of the wheel well. I cut a hole in it. Then I've attached a velocity stack on to that.
I've driven it like that for 7 years without any problems. Rain has not been a problem as the filter is at least 24" from the pickup point. I do avoid WOT in heavy rain or areas of standing water.
Again, I'll post pics as soon as I get it fixed. I placed the order for it a week ago.
Ruf
Ruf
I can get you part # for the K&N filter that fits perfectly overtop of the velocity stack. I don't know what brand of VS I have, but here's a picture of it. I know there's a couple different sizes out there.
http://www.lowes.com/lowes/lkn?actio...100&lpage=none
Ruf
You can still add a VS to the end of that. It's just easier to exend the CT Icebox because the design puts it in a perfect position to extend it outside of the wheel well and expose it to direct outside air and you get the ram-air effect.
It's hard to get the correct dyno numbers because you don't get the increased air speed as you accelerate. But most show 4-5hp for static air and I'm guessing you can get another 3-5hp when your over 90mph.
Ruf
Ruf
Still waiting on my replacement part so I can repair my set up and will post pics as soon as I get it.
Also, Excelerate carries the Vibrant line of velocity stacks. If we can agree on a size and get a volume deal going maybe we can save a few coins. Just a thought if several of you guys want one.
http://store.excelerateperformance.c...s/g-54372.aspx
Ruf
Ruf
im running the blox velocity stack and it hauls ass screams loud but it hauls. im thinking more then 5hp because i really feel it. I have it coupled to the stock rubber piping trying to get a new pipe. you can get the filter with the velocity stack built into it. 3'' inlet. check weaksauceparts.com
09-17-2015 09:01 PM
