Variable Vane Turbos
Old Jul 8, 2004 | 04:57 PM
Zapata's Avatar
Cost Drivers!!!!
Pretty cool technology. Basically, the system varies the angle of the vanes in the turbo to match output Pretty f'n cool. HOpfully this finds it's way into Acura lineup along with SHAWD and IMA.
Honda's turbo in the diesel versions of the new "3x2" Edix Minivan: JDM Edix and Euro FR-V.
http://dwolsten.tripod.com/articles/jan89a.html
reprinted from Automotive Engineering, January 1989
Honda's success in Formula One Grand Prix racing with a generation of turbocharged 1.5-liter engines should long remain legendary in the history book of motor sports. Curiously, Honda abstained from the production car turbo application since the demise of the furious City Turbo II mini runabout several years ago.
With the formula change coming in effect in 1989, Honda is tackling the Grand Prix racing with yet another unique power plant, a quad-cam, naturally aspirated 3.5-liter V10 engine. On the other hand, it is applying its considerable accumulation of turbo technology in a production car, a Japanese version of the suave Legend sedan.
Called "Wing Turbo," the instrument is a variable geometry turbocharger of Honda's inhouse design and manufacture, that employs four pairs of stationary and pivoted movable wings in the turbine housing. The wings are made of heat resistant Inconel alloy.
A watercooled intercooler is situated between the banks.
The movable wings are positive pressure- and vacuum-operated, their angle changes are controlled by an eight-bit 36-kilo byte computer that also manages fuel injection. Positive pressure to the wing actuator is supplied by the turbo's supercharge pressure, controlled by a frequency solenoid valve, and negative pressure is generated by intake vacuum and accumulated in a reservoir which is also solenoid controlled. The CPU is fed signals including boost pressure, intake temperature, coolant temperature, throttle opening, engine rpm, and vehicle speed. The Wing Turbo is not fitted with a conventional wastegate.
On idling and steady-state cruising that do not require supercharging, the movable flags--or wings--which are fully opened, allow exhaust gas to enter the enlarged nozzle area and pass through the turbine smoothly with little resistance. At the beginning of full acceleration, the wings close fully, reducing the nozzle area through which accelerated gas enters and strikes the turbine blades forcefully, gaining boost quickly. When maximum boost is obtained, the movable wings begin to close gradually, until the vehicle reaches a desired cruising velocity whereby the wings open fully. The nozzle area varies continuously according to operating and load conditions.
Honda's variable geometry "Wing Turbo."
As installed on the two-liter version of Honda's 90° four-valves-per-cylinder V6, a maximum boost of 450 mmHg is reached at as low as 2000 rpm, improving the engine's torque output and response on rapid acceleration. Combined with an electronic ignition control, employing knock sensors, the Wing Turbo allows an unusually high compression ratio of 9.0:1, contributing to the engine's high output as well as good fuel economy.
The 2-L Wing Turbo engine is fitted with Honda's PGM-FT electronically managed fuel injection, and its boosted air is intercooled by a watercooled intercooler mounted between the cylinder banks. The intercooler water is cooled by a separate radiator and circulated by its own pump; the system has a cooling capacity of 5600 k-cal/h, and lowers intake air temperature by as much as 36°C.
One of four pairs of wings is seen in its
fully open position at idling speed and
steady-state cruising, letting exhaust gas
flow through with minimum resistance.
The Wing Turbo V6 produces 142 kW JIS net at 6000 rpm and a maximum torque of 241 N·m at 3500, which are superior to those of the naturally aspirated 2.7-liter version that powers senior (and U.S.) Legend models which are by the Japanese ratings 134 kW and 226 N·m, respectively. If there is any penalty in the Wing Turbo installation, it is probably an added weight; about 40 kg over the straight-forward two-liter V6.
The Wing Turbo V6 is mated to Honda's electronically controlled four-speed automatic transmission, and drives the front wheels of the four-door sedan.
Old Jul 8, 2004 | 08:07 PM
Bobbydoedoe's Avatar
I'm Cool
nice find, but i got a question the last line of the article says "The Wing Turbo V6 is mated to Honda's electronically controlled four-speed automatic transmission, and drives the front wheels of the four-door sedan." anyone know which car are they refering to?
Old Jul 8, 2004 | 08:15 PM
mattg's Avatar
that article is 15 years old.
how can it be worthy news?
dukmahsik's Avatar
too bad honda doesnt like turbos for their cars
Old Jul 8, 2004 | 09:06 PM
Zapata's Avatar
Cost Drivers!!!!
lol mang that's the turbo they are using in the accord i-CTDi and the new min-van type vehicle that's being release. Moreover, if rumors hold then you'll see this turbo available as performance package or performance variant of the TSX w/ SHAWD.
Zapata's Avatar
Cost Drivers!!!!
legend
Old Jul 8, 2004 | 10:17 PM
Edward'TLS's Avatar
6G TLX-S
Variable vane turbo had been used by Dodge back in the 90's. Dodge called it Variable Nozzle Turbocharger (VNT). Dodge put the VNT in the Shelby CSX which is basically a factory souped-up Shadow. Since the turbo vanes could move according to the driving conditions, the VNT acted as a small turbocharger at low speed and as a giant turbocharger at high speed. Turbo lag is virtually non-existance. However, this then-new turbocharger was dropped the following year due to too many warranty claims. The problem was that the constant vane movements had overtaxed the vanes which then started to fail. But that was over 10 years ago, and it was Chrysler/Dodge technology !
Old Jul 8, 2004 | 11:08 PM
darrinb's Avatar
///M POWER
i think this is the same system used in the turbo 600 benzes
Feb 25, 2020 09:57 AM
Slow98teg
30
Jan 2, 2017 09:01 AM
mvidal6
ILX
Nov 14, 2015 07:43 AM
joflewbyu2
Oct 8, 2015 11:16 AM
CLsuperhero
Sep 23, 2015 12:53 PM
