Valve Cover Gasket parts Help
Old Sep 15, 2011 | 02:57 PM
WILLDOGS's Avatar
I shave my change purse
Sup Guys
I'm getting ready to order the gasket(s) needed for valve cover gasket job. I've got some oil coming out of the ridght side and need to take care of it.
Other than the two Valve cover Gaskets (No. 4)
What else do I need?
I can't tell from the pic, but is No.5 Gaskets that go around each Spark Plug?
Also, should I replace the gasket around the Oil Filler (No.7) ?
I assume I need the Following
Qty | Part
2 - No. 4
6 - No. 5
1 - No. 7
Old Sep 15, 2011 | 03:35 PM
1sickaccord's Avatar
Part #4
Part #5
Part #10
Old Sep 15, 2011 | 05:16 PM
civicdrivr's Avatar
Just get two #1s, PN 12030-P8A-A00. Each kit comes with the spark plug seals, valve cover seal, and the caps.
I can't find the price for the spark plug seals alone. They come with the valve cover itself or in the kit mentioned above.
Old Sep 15, 2011 | 05:19 PM
StreetKA's Avatar
just get the valve cover gasket that what i did and i'm fine
Old Sep 15, 2011 | 05:59 PM
aznboi2424's Avatar
The only I replaced when I got my valves done were 6 number 5s and I don't think I have any problems.
I was able to buy them seperately civic.
If I knew about the other gaskets, I probably would have at least gotten the number 4s. Oh well, next time.
Old Sep 15, 2011 | 06:06 PM
civicdrivr's Avatar
Yep, I did some more digging and located the PN for #5 - 12342-P2F-A01
In which case Id do #4 (x2) and 5 (x6).
Old Sep 18, 2011 | 11:49 AM
WILLDOGS's Avatar
Thanks all! I think I am going to go this route. Didnt even realize that #1 was the actual whole kit LOL
Thanks again
Old Sep 18, 2011 | 12:31 PM
civicdrivr's Avatar
You can save some money and just get #4 and #5. IIRC that will save you about 50%. Those caps are expensive and can be reused. Thats the only other thing the kit comes with.
Old Sep 18, 2011 | 02:26 PM
WILLDOGS's Avatar
Thanks for the tip but I rather be safe than sorry and just spend the extra $$ for the whole kit. It's Not that much money IMO.
Old Sep 18, 2011 | 03:05 PM
civicdrivr's Avatar
True.
Old Sep 19, 2011 | 12:24 PM
WILLDOGS's Avatar
I'm also gonna replace the spark plugs and o2 Sensor(s) at the same time while I have things going...
Im going to stick to stock NGK's which havent been changed since 75k miles. I curently have 170k miles on the CL.
Also, I still have both Stock o2 sensors on my car. Never been changed and i'm getting horrible mileage right now. Think its related.
Do you think I should get both 02 sensors? Front and Rear? Or just the front?
Also do I need to get the sensor from Acura? Or will I be safe going aftermarket and splicing the connector?
Old Sep 19, 2011 | 01:23 PM
civicdrivr's Avatar
You can get an aftermarket sensor. Make sure its not a Bosch.
Also, make sure you gap the spark plugs - 1-1.1mm gap is whats specified for the Type S. You have a CL-P, right? Check the sticker under the hood. The measurement will be there.
Old Sep 19, 2011 | 01:36 PM
WILLDOGS's Avatar
Awesome thanks again for the info. Found both denso sensors on amazon way cheaper than Acura.
Gonna order them now.
Thanks!
Old Sep 20, 2011 | 01:44 PM
aznboi2424's Avatar
Shouldn't they come pregapped? Especially if he got the OEM NGK lazer platnium/iridiums?
Old Sep 20, 2011 | 02:25 PM
WILLDOGS's Avatar
Good Question
These are the ones I have on order, should be here tomorrow
http://www.amazon.com/gp/product/B0000VY0K0
Also, do I need to remove the Intake Manifold in order to get to the front and rear valve covers? Or can I get away without removing the IM? I have the Helm's but it isn't too clear.
Also I cant find any instructions in my helms just for replacing the Valve Cover Gasket, they do have instructions on adjusting valves, so I am just looking at those steps to remove the valve cover.
Old Sep 20, 2011 | 03:18 PM
aznboi2424's Avatar
Gotta remove it. My mechanic even went to as far as removing my strut bars to get more room cause he was adjusting the valves.
Old Sep 20, 2011 | 03:45 PM
WILLDOGS's Avatar
Crap. Do I need to get new IM gasket? or should I just re-use the original one? I didnt order any new gasket for the IM.
Also while the IM is off? Anything I should do with it? Clean it? If so, how?
Old Sep 20, 2011 | 04:06 PM
aznboi2424's Avatar
You can, I did. But since you rather be safe then sorry....
You'll need 2 intake gaskets.
Old Sep 20, 2011 | 05:41 PM
WILLDOGS's Avatar
Whats the worst that will happen if I keep the re-use the original gaskets? Are they made of rubber? Paper? Easy to tear?
Old Sep 20, 2011 | 06:10 PM
civicdrivr's Avatar
Not the set I just bought for my car and my brothers Accord....
The IM gasket is metal. You can reuse it unless its in rough shape.
Old Sep 20, 2011 | 06:12 PM
WILLDOGS's Avatar
Gotcha thanks. Not being cheap since the IM gasket only costs like 15 bux, its just that I plan to knock this all out either tomorrow or Thursday and didn't order an IM gasket which would then delay me a bit if I ordered now.
Old Sep 21, 2011 | 01:15 PM
WILLDOGS's Avatar
Good news and bad news.
Good news is that upon closer inspection it looks like its not my valve cover gasket after all
Bad news is that I have a shit load of oil coming out of the side where #15 O-Ring and #6 From Cam Shaft Thrust Cover goes
Uploaded with ImageShack.us
How often does this o-ring wear out? Is it possible I can just tighten it up? Is this a generic o-ring? Or do I really need to go get this $.84 cent part at the dealer?
And I just picked up my two valve cover gasket kits from the dealer half hour ago lol. Might as well do the whole job while I have the parts anyway.
Old Sep 21, 2011 | 04:11 PM
WILLDOGS's Avatar
Ok so I got some tools out to tighten the cap up but everything is tight and now it doesnt even look like there is an oil leak from that side cap at all?!!?
There is oil caked up on the inside of the cap, but the outer edge of the cap (where the seam is) is clean.
All I can think of in that area is that the EQR valve is spitting out oil? Is that possible? From my spidey sense detective skills, It looks like the EGR is possibly spitting out oil towards the side of the head and dripping down.
I cleaned up all the oil and will monitor the area to see if I can figure it out.
Is this a known issue?
I'm searching the interwebz now.
EDIT: Now that I think of it, when I WOT my car, it has been making a sort of popping noise when switching gears at high revs. I chalked this up to a backfire because I am running a bit rich.
Could this pop be when the EGR spits oil out? Hmmm
Other than needing a tuneup and getting 17MPG, It is running great. I'm hoping the new plugs and O2 sensors will help with the MPG and running rich problem.
Old Sep 21, 2011 | 10:59 PM
WILLDOGS's Avatar
This is what is looked like before I cleaned it all up
I've put another 20-30 miles on the car since I cleaned it earlier and not a drop of oil anywhere. This is driving me nuts.
I'm going to purposely go WOT a few times tomorrow to see if it makes oil pop out from anywhere.
Old Sep 22, 2011 | 01:12 PM
civicdrivr's Avatar
Just pull the EGR valve off (get a new gasket for it), and replace the O-ring on the cam cap. I doubt the oil is coming from the EGR valve itself. If you have the intake off, check your EGR port. If its clogged, clean it out. Theres a tutorial on the TL side IIRC.
Old Sep 22, 2011 | 04:28 PM
WILLDOGS's Avatar
Good tips thanks. I'll see if I can get to it after the rain stops sometime next week
I was just able to swap spark plugs, clean out the TB a bit with cleaner and replace both o2 Sensors today before the rains started. Car drives so much better. Now to see how good my MPG goes up.
Here are the old plugs after putting about 100k on them
They look ok no?
Old Sep 22, 2011 | 08:48 PM
civicdrivr's Avatar
Yea, they look normal to me.
Old Mar 21, 2012 | 09:14 PM
WILLDOGS's Avatar
Bump
FYI I never used these gaskets and still have them for sale along with a few other Cl parts
https://acurazine.com/forums/car-parts-sale-361/new-engine-suspension-parts-835879/
I'm about to get rid of them soon, so make offers via PM
thanks
cycdaniel
Dec 17, 2019 10:58 AM
kmarqueling
Oct 3, 2015 01:14 AM
sockr1
Oct 1, 2015 01:31 AM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
hand123
Sep 10, 2015 09:29 AM
