ur crank pulleys
03clslambostyle
ur crank pulleys
i have the ur crank pulleys, now is it wise to put them on myself or have someone do it for me? Dont you need a belot timer or something like that, or can you just loosen the belt and put it on then tighten it back up?
how handsome I am
if you dont know what you're doing, have this install done at a shop. It is VERY important that you get it put on and timed correctly... otherwise, you could damage your engine reeal bad.
Never had a clean run
My dealer wanted to charge me $400 to install the crank pulley! BAstards. I'm gonna find a local speed shop to do it. MrSteve said he got his done for under $200.
Originally Posted by typeR
is is straight forward and can be done in the home garage...you will however need a large breaker bar...i used the method of pinning the breaker bar to the ground and removing the fuse for the ignition coils and turning over the car to break the bolt free...it is important to remove either the fuel pump fuse or ignition as you do not want the car to start...just turn over...there's a DIY post on this method at V6.net
how handsome I am
Originally Posted by mclarenf3387
WTF are you talking about? There is no timing on the crank pulley.
Sorry for not wording correctly. Either way, it's an install I wouldnt do by myself.
![Sorry](https://acurazine.com/forums/images/smilies/sorry.gif)
-Alex
hmm.. sorry. Im speaking about what I remember from the UR Pulley kit install on my car... Crank pulley is connected to alt/power steering through the belts... if those arent put together correctly, then the whole engine goes to poop.
Sorry for not wording correctly. Either way, it's an install I wouldnt do by myself.![Sorry](https://acurazine.com/forums/images/smilies/sorry.gif)
-Alex
-Alex
03clslambostyle
hey i tried v6.net, and it brung up music download crap. whats the actual website. im good at working on cars, just that i dont know all the websites yet.
Former Sponsor
Originally Posted by dshearon
TypeR, how did you get the 181 ft lbs of tourqe on the crank pulley. the only tourqe wrenches i have been able to find go up to 151 lbs....
i understand how to get it off.... i am just having trouble finding a tourqe wrnech that will go to 181 lbs so i can put the new one on....
sorry to ask so many questions but i have an electric impact gun... do you think that will get it tight enough or do i need to use and air one?
Usually electric ones aren't that powerful, but it maybe powerful enough.
acuratl26
04-23-2020 07:30 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
