UR Crank Pulley problem? Experience?
ex 6 Speed owner :(
Not on my CL but the Accord... looking for some help:
For the hell of it, since I had to pull the crank pulley to replace the timing belt / water pump anyway, I put on a UR Crank Pulley. I am 100% positive all the belts are on correct (balancer belt in particular). I noticed IMMEDIATELY upon startup the engine does NOT run smooth like it used to. It is like one of the balancer shafts is out of whack but I am sure it's aligned the same way it was when I took it off. Any ideas what's going on here?... does the pulley make that much of a difference!? Did those of you with UR Crank Pulleys experience something similar? Help I don't want to ruin my engine... that was a pain in the ass to install too...
Re: UR Crank Pulley problem? Experience?
I would take th evalve-cover off... crank the engine until its TDC and make sure everything is lined up.
Sweet as Gold
an older accord w/ the balancer shaft running thru it right???. Check the tension on your belts...I've experienced this problem before w/ them being too tight or even too loose.
ex 6 Speed owner :(
The funny thing is I just took the engine apart again and found that both belts were a tooth off, so I fixed that and to my surprise it STILL runs a little rough. Checked Ignition timing, triple checked all the belts... it does not run like it used to. What the hell!?
Oh and I DO have an 8 lb. aluminum flywheel in the car too... maybe the crank is TOO light now? I wish I could have the crank re-balanced... it is pretty old
But I just got here
I thought I had read somewhere that you should not use the crank pulley with an aftermarket flywheel?? Something about the pulley screwing the flywheel up because of the vibrations. Don't quote me on that though.
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
