UR Crank Pulley Install ?
Has anyone here installed there own ur crank pulley? Is it a pain in the ass? Any special tools needed? I plan on installing mine tommorow night if it's not that bad of a insall.
Bleed Honda Blue
Adventurist.
Now, the other problem is torquing the bolt down CORRECTLY. 187 ft/lbs right? Correct me if I'm wrong... Most torque wrenches only go to 150 (mine does at least).
it's cake worse case scenerio you disconnect the fuse for ignition using a breaker bar pinned against the floor and turn the car over with a good size breaker bar you should be able to do it by hand ...some one will have to hold the breaks though
i am sure it would work..but...
BoricuaTL
04-08-2016 01:08 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
