Upgraded brakes
Upgraded brakes
Hi everyone.
I'm looking to upgrade my stock brake calipers form a one to two piston caliper. Does anyone know for sure if a set of Brembo Acura TL 2004-2008 calipers will fit on a 2003 CLS? thanks
Paul
Paul
Originally Posted by m733l
i believe you need to make a custom mounting braket. it is not a direct fit.
That should be totally safe!
Not knocking you, just saying that does not sound safe.
This has been discussed & may be only a few hundred cheaper then a real BBK.
The brembo setup on the TL isn't a very good setup anyway. It's a very low end system. Only marginally better then the stock CLS brakes.
And no it's not a direct swap. As stated you need to fab a new mounting bracket.
Former Sponsor
I have never performed the swap but look up the Legend caliper swap. It is a 2 piston caliper. So if you are trying to keep the costs down get better rotors, Legend calipers, pads, and stainless steel brake lines. If you want a BBK get a ROTORA 1 PC 13" Disc 4 piston caliper setup.
Jul 16, 2017 07:33 AM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
