Update on Royal Purple 5w-20
ok well ive had royal purple 5w-20 since 4-18-03 and now its 11-10-03
roughly 7 months and about 8000 miles
the car has been in 105 degree weather to 50 degree weather since and i have had
ZERO problems
plan on changing the oil next week
sidemarker
ZERO problems
sidemarker
Zero problems but you really won't be able to tell how good it is until you send it out or performa a sample check on it. I could probably leave dino oil in there for 15K miles with "zero problems" but the problems will show later in the long run.
Re: Update on Royal Purple 5w-20
ZERO problems
sidemarker
ZERO problems
sidemarker
So where did you get the oil from? How much was it? And is it fully synthetic oil?
I use this stuff as well but change it around 7500 miles...I get mine from a local motorsport place that builds race and drag cars. It's about $35 for 6 quarts...
The guys there tested it themselves (for whatever that is worth) and claim it gave them between 2-5hp on race motors and ran about 20 degreees cooler on average than Mobil 1...
I use it because someone had a thread on it about 7 or 8 months ago and espoused the stuff. It's only a little more than Mobil 1, so I'm just being different...
Re: Re: Update on Royal Purple 5w-20
Originally posted by PimpinCLS03
Sup Bro,
Sup Bro,
sidemarker
sample check would be a good indication of how well the oil is maintaining its viscoisity but does anyone know where i can send it out too and how??
sidemarker
Blackstone Laboratories is where I go to have my oil analyzed. It takes about a week after you drop the sample in the mail. Email Blackstone Lab (bstone@blackstone-labs.com) or call (260) 744-2380 for a free mailing kit for sending your sample in.
Important: Blackstone will give you the raw numbers, but you should ask for the "Dyson Analysis Package and Code #46" in the comments section of the paperwork you send in with the sample. They will automatically send the sample results to Terry Dyson for an in depth analysis of what each of the numbers mean from Blackstone's analysis.
I wouldn't go any other way than Terry's final analysis. He invites questions if you have any after you get his results.
The total cost is $35 and you can have it charged to a credit card. I believe the mailing cost of the oil sample to Blackstone is $1.52.
Go to http://bobistheoilguy.com/terry.html for info on Terry Dyson.
The claims for increased HP are true BUT the additive package that makes it so is questionable if it holds up after a couple of thousand miles. The only test would be to dino test yourcar before adding new (royal)to baseline, dino test when new then dino test after 7k miles.. Have some new oil and 7k oil sent to lab for analysis and compare with each other. Remember most race engines are rebuilt after a few 100 miles and new oil is always put back in. Also they like to change trans oil and rear end oil with race oil and then show the composite of all the HP gains.
Most of our street cars are not race cars. I need my syn oil to last 10k miles which it does.
Also the claims for using 5w20 is just corporate BS,,
http://www.desertsundirectsales.com/ford5w20.htm
Most of our street cars are not race cars. I need my syn oil to last 10k miles which it does...
Of course after forking out the money for the oil analysis, and dynometer tests, I'd be asking myself, 'is this really worth it?'
http://royalpurple.com/techrp/summary.html
http://royalpurple.com/video/video.html
Originally posted by 360
Here you go
Here you go
navtool.com
31
11-16-2015 08:30 PM
lanechanger
10-13-2015 10:56 AM
