Update on cams
Old Oct 21, 2003 | 08:52 PM
BoostedM3's Avatar
Bagged hybrid
Update on cams
I've been looking into billet cams for the CLS recently and this what I've found so far about our stock cams (from v6performance).
Lobe heights
J32A2: 34.737 (Primary), 36.445 (Vtec), 34.919 (Secondary), 36.389 (Exhaust)
I don't have any extra set of cams (yet), so I can't get them measured for lift/duration and I can't seem to find them anywhere. I know that the AV6 has duration of 194/200 @.050 (non-Vtec) and 215/200 @.050 (Vtec). No lift numbers to be found.
If anyone has a set of CLS cams that they can measure or let me borrow to measure, that would be great. Once I get the specs, the cam shop can make a billet one for me in a couple days and I will do before & after dyno. If gains are significant and people are interested, a group buy of 5-10 minimum can be setup (~$600 or less).
Old Oct 21, 2003 | 09:06 PM
mattg's Avatar
someone help this man.
Old Oct 21, 2003 | 11:01 PM
hellas's Avatar
cant you just look up the specs in the shop manual?
Old Oct 22, 2003 | 03:23 AM
johntypes's Avatar
I in, hurry up we need spec.
Old Oct 22, 2003 | 06:48 AM
CLS2001_97124's Avatar
Revving at 9K...
This will be the perfect mod after the chip.
Old Oct 22, 2003 | 09:05 AM
BoostedM3's Avatar
Bagged hybrid
I've asked around and no one knows the exact specs.
Jens, can you possibly find out?
Old Oct 22, 2003 | 09:06 AM
BoostedM3's Avatar
Bagged hybrid
Exactly
Old Oct 22, 2003 | 09:53 AM
Revving at 9K...
Actually, before the chip would be even better...
Unless changing the cams won't affect air/fuel, timing and all that good stuff. ???
Old Oct 22, 2003 | 09:54 AM
MtBikR's Avatar
Ronnie are you going more more agressive cams or just replicating our stock internals out of billet for strenght? If you going for power addition as well, please add me to your group buy. Thanks
Old Oct 22, 2003 | 10:09 AM
BoostedM3's Avatar
Bagged hybrid
Jens is looking for the specs.
Well, my plan is to get these cams and do before & after dyno with i/h/e/crank. Then after that, I want to see if the e-manage/chip could fine tune it in case the ECU doesn't adjust well with it.
MtBikR - More agressive of course! I still dunno if I need to change the valve springs...some say yes while others say no. I guess it depends on how agressive, but I don't want a rough idle....
Old Oct 22, 2003 | 10:42 AM
typeR's Avatar
i thought someone had a set they were sending to web cam
Old Oct 22, 2003 | 10:44 AM
BoostedM3's Avatar
Bagged hybrid
That was me , but i don't want to buy a set just to get it spec'd...only if I have to, then I will.
Old Oct 22, 2003 | 10:50 AM
typeR's Avatar
ok ...i did a search but couldnt find the thread where you had said that
Old Oct 22, 2003 | 11:14 AM
BoostedM3's Avatar
Bagged hybrid
This is when you brought up the topic & I mentioned it.
http://www.acura-cl.com/forums/showt...highlight=cams
I've been talking to allmotor about it, so maybe you heard from him?
Old Oct 22, 2003 | 06:01 PM
BoostedM3's Avatar
Bagged hybrid
Damn, all Jens could find is the lobe height also. I guess I'll have to find a set to get spec'd. I'll keep you guys updated.
agupta3224
May 23, 2017 08:30 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
thegipper
Sep 28, 2015 01:01 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
