UniChip Possibilities
Originally posted by MtBikR
I have been following your emanage thread intently. How differnent is my harness going to be than your 6 spd one? Is it possible (this might be an aside topic) to remove me VSA or permenantly disable it? Thanks
It is possible to remove the VSA throttle and control from the system. You just need to fool the ECU into thinking it is still there though with is also easy enough.
Originally posted by scalbert
I might even make them available by having my technicians wire them up with the e-Manage harnesses already installed.
Heck, I might even make them available by having my technicians wire them up with the e-Manage harnesses already installed.
Originally posted by ModAddict
BTW, I got my best time with VSA on.
who'd of guessed? Any advice on your launching methods? Do you just kinda "roll" the pedal into the throttle? This was your 13.8 I assume too? Great time BTW!
I brake torqued just a bit, and added maybe 1/3 throttle at the green light,...one big wheel hop, a bit of a bog, and off we went. I could not repeat it again with only one hop, but did have a few 13.9s also. It was my first time down the 1/4 mile, and I don't see going back, as it seams hard on the old daily driver. I don't like the wheel hop,...sooner or later something's going to break. If we can cure the hop, I might consider going back.
btw, for all that actually cares about what kind of gas milage to expect. I know the gas milage I've posted last time included several hard runs with Matt. So I thought I share with you guys my latest MPG stats.
Note: I filled up last week without topping it off, and I took notice the trip A number as soon as my gas light came on. I'm not exactly sure how many gallons before the light comes on. This is after driving exactly the same highway to streets ratio, including rush hour traffic.
I hit 267 miles. Before the chip, I average about 280. Not too bad at all.. about 10-15 miles per tank if you be nice...
Originally posted by CLS2001_97124
Oh definitely more to come...
Now that I got the clutch and flywheel upgraded. I'm ready for the Aftercooler and the higher boost pulley.
Comptech told me that I'm the next person inline as soon as they build the next batch of AC's..
No pun intended
Yeah, Jack from UniChip emailed me, and we should be getting the new numbers in a few days, and he also have scheduled my car back in so we can try out the Vtec Controller and see if that makes any difference. I will post the new dyno as soon as I get it.
Originally posted by moomaster_99
Give up on the Unichip, guys? I tried it about 1.5 years ago... we could never get it tuned right in Sonoma
but if everything goes like we hope it does with the e-manage, Brians' Unichip will be one of a kind.
Originally posted by mattg
well, we were able to get it tuned right in Portland.
Hi everyone, sorry for the delay. I caught the recent flu, but I'm all better now. :o
Anyway, here is his latest response to me about the Vtec point, and raising the rev limit.
Brian,
Sorry you got sick... I hope you're feeling better. I assume the car continues to do well. I thought I had sent you the dyno sheet... but one way or the other, here it is.
To answer your questions, yes we can raise the rev limit, but it requires work inside the ECU; we can do it but (1) guys will have to send in their ECU's and (2) there really aren't many good reasons to do it... many people think they get more power by raising the rev limit because they look at the bhp curve and it frequently continues to go up. As we've discussed, however, torque is what accelerates the car and that decreases even if you increase the redline. We'll be happy to do it, but unless someone is trying to save a shift during some sort of competitive event, raising the limit is more trouble and cost than it's worth.
Yes we can drop the VTEC point, and the cost will be around ~$85... it will be an additional part attached to the standard PnP harness.
Cheers,
Jack
So it's you guy's call if we want to start any type of group buys in order to get the PnP harness, now that we have the e-manage as another option.
Steve, can you shed some light to people here who is not quite as technical on that exactly is involved if the N/A guys wants to use the E-manage rather the uni-chip? Any additional cost after buying everything that is needed? Tuning? Install?
Thanks!
Btw, I have the new dyno with torque curve, but it's in PDF, does someone here know what to post that? I can email it to you later today.
Brian,
Cheers,
Jack
Thanks!
About the e-Manage, right now power gains are unknown but in theory they should be about the same. For a PnP harness; that is also in the works and should be available soon. Within the next month or so we should have a dyno plot available and the PnP harnesses ready (or at least the parts available).
As for the differences, I won't go into the technical aspects of how each does what it does although the fueling changes use the same methods; the timing is different. The main difference is that the e-Manage is programmable and the software readily available for an additional charge.
Also, you can purchase the e-Manage right now, along with all options (excluding the pressure sensor) for about $470. However, this would require hard wiring the unit and complete tuning. Hard wiring would call for tapping or splicing in about 28 conductors into the factory harness. This would be messy and difficult with the limited space not to mention you would not be able quickly remove the unit if needed. For tuning a dyno session with A/F monitoring should be used. This is normally about $100 per hour and expect at least three hours on the rollers.
As mentioned, I am working on getting a PnP harness ready for both the 5AT and 6-Speed. At the same time we will be tuning an NA car with the standard mods, I/H. What should be available are a few options. These are not absolute prices, they are just budgetary numbers until everything is known.
System with the e-Manage main, injection and ignition harnesses pre-wired to a plug and play harness. Without the support tool but with the unit configured and a program loaded for the specific application (NA or Boosted): $550
Same as above but with the Support Tool allowing for custom tuning: $670
Hope this helps....
Great. I guess, now it's up to the people here to decide if they want to get the UniChip w/ PnP harness up and going.
If not, the chip is still avilable for hardwire.
btw, can you pm me an address I can use to email you the pdf?
Hope this helps....
Hope this helps....
Those prices sound very reasonable if the gains are decent. If you buy the system without the support tool, can you get the support tool later?
Thanks for the info and please keep us updated.
juice
In addition to what I stated, to hard wire the Unichip is much simpler than the e-Manage. There are significantly less number of wire splices and taps from what I have gathered so far. This would make self installation much easier with the Unichip without a PnP harness.
Just FYI...
Nice gains. What is that between 5-10 lbs of torque throughout and 5-15 hp throughout at the wheels? I've been a way for a few weeks but it sounds as if the e-manage should be able to get the same gains. So are we just waiting for the final price of both w/ the PnP harness to see which way the N/A guys plan on going?
Thanks Steve for hosting the dyno.
The price for the Uni-Chip is around $700-750. With or without the PnP harness. If we start a group buy it could be lower. They will make the harness basically if we can get 20 people to buy it. Otherwise people can buy the chip now from them directly doing the hardwire method.
well the gains are a little higher than that from my inspection, but more importantly they are throughout the entire power band not just in some areas... a cai doesnt do anything for low end torque, this does. also with more mods this could improve i assume...
