Turning rotors
Turning rotors
Hello all,
I was just at my local Acura dealer, and was told something I find hard to believe and would like to know if anyone else has experience with this. I have a break problem and had my rotors turned at a reputable place, but my problem is still there. When I took it to the dealership, they asked if I had the rotors turned on or off the car? I informed them off the car, and they said that could be the problem. Acura turns their rotors on the car, so that they are turned to match the suspension. That sounded a bit strange to me, seeing the car is up in the air and the suspension extended. I was informed turning the rotors off the car, you could actually put a shake in your car. I would like to know if anyone has experience in this matter to tell me if they are right. I can't see how if you turn a rotor off the car, it could be wrong on the car. thanks again guys.
OG 3.x^7 rawr
This is very true. Many dealerships are required to have ProCut for turning rotors. This method is very accurate. When removing the rotor and putting it on the bench to machine, the rotor is machined to the hub of the bench machine. With Procut, the rotor is on the car and is matched with the hub of the car. The machine does a visual of out of spec. Then starts to cut. I've seen it done and its very accurate and produces a nice finish. It also cuts the rotor in non-directional so when moving forward and reverse there is no pad movement. Takes about 10min to machine and you do not have to remove the caliper bracket, just the caliper itself.
What type of problems were you having? brake shimmey?
lowrd on tein CS biatch
when does the wheel shake... only when braking at high speeds? only after they are heated up? only when u thresh-hold brake, or does it slightly vibrate all the time on the highway and then get worse when u brake and speed makes it worse?
Before you answer: My guess is they start to shake when u brake from 40mph or so or higher. and it gets a little better if you smash on the brakes. But if you apply even pressure at highway speeds. the Wobble gets worse and worse (as the heat builds up)
This is because the rotors are actually 100% straight but SINCE they have machined and maybe more than once, the thickness of the rotor is not the same and that is what makes the rotor able to take the heat (the amount of and quality of the metal on the rotor).
FYI i had breaking issues when i purchased my car... went to acura and the machined them perfectly... and as soon as the rotors heated up at all they went to JELLO!!
wheel was all over the place. it was a disgrace.
Both times I got rotors turned (different brand rotors, and went to a different place) the result was the SAME...extremely disappointing and I immediately threw them in the trash.
go get urself some aftermarket brakes and decent pads.. I would recommend slotted only.
I had drilled and slotted DBA rotors and still warped them after 12 months of PUNISHMENT. so I got DBA fronts.. slotted and hawk pads. about 440 in total but god damn... the brakes CANNOT fade or wheel wobble EVER..
unless u track the car.. then ur gonna need a BBK. but hey what do ya expect
Whats up with RDX owners?
OG 3.x^7 rawr
lol, i've turned my previous rotors before and I brake late and hard. It really depends on the material and thickness. Thats why you guage the thickness before you machine the rotor. If it close to minimum I don't even bother. Or if its warped to hell.
Are you saying if the rotors that were turned were quality rotors, and turned on a good machine, they should be fine? Earlier it was said they have to be turned on the car or they could still be bad when installed after having them turned off the car? I'm confused now.
I was answering your question about the manufacturing process.
Yea and depends on the price. If you're running high quality performance rotors thats alot of money to throw away on a new set if your current rotors can be cut.
mada51589
05-03-2022 08:54 PM
