Turn signals not working
Old Jul 20, 2005 | 02:18 PM
Nofear6370's Avatar
Silver Bullet
I was driving and I had my left turn signal on and all of a sudden the green arrow inside stopped flashing, the signal lever was still down. I pulled over and checked it out, basically when I signal it flashes once or twice and then stops. The lights outside stop blinking too?
I need to check the fuse but I am almost positive that if it was the fuse they would not work at all. I am thinking it has something to do with a relay switch or something.
Anyone have any ideas as to what it could be ? Or had the problem before?
Old Jul 20, 2005 | 03:40 PM
louisn's Avatar
Could be that one of your outside bulbs has gone south?? I think if a bulb burns out your inside turnsignal stops flashing. Not sure though!!
Old Jul 20, 2005 | 04:24 PM
Nofear6370's Avatar
Silver Bullet
It is definitely not the outside bulbs they work initially when I signal until it dies and I have to resignal.
Old Jul 21, 2005 | 12:24 AM
DURAN007's Avatar
Same thing happened to me. It is not your bulbs! It is your relay for the flasher. Go to the dealer and have it replaced. They will tell you there is two flasher. I can't remeber which one it is but the whole thing cost me around $ 120 to fix.
Old Jul 21, 2005 | 11:24 AM
Nofear6370's Avatar
Silver Bullet
Thanks for the info, I had a feeling thats what it was. I had a similar problem on an older accord. I will have to get it done at the dealer soon.
Thanks,
acurajj
Sep 19, 2015 03:47 PM
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
