Turbo Kit Progress.... (pics)
#42
Sold but not Forgotten...
Originally posted by scalbert
With 5AT upgrades it could be done. But knowing this crowd it may not be worthwhile investment.
With the upgraded tranny will it be able handle the power? How much work would it be?
Thanks again for your valuable input
#44
looks good so far all-motor. So you are using 2 side mount IC's instead of an FMIC? I know twin turbos setups are tough to plumb to an FMIC, but it looks so cool. And with the low boost you are running, I don't think you will need a lot of cooling capacity anyway no?
#45
ex 6 Speed owner :(
It is a single turbo set-up... so we're running a FMIC . I think that will look pretty intimidating on a CL. The intercooler is a custom sized Garrett unit (that I've been waiting 3 months for) with the high-efficiency fin design to attain the lowest charge temperatures possible because of the high compression ratio.
#47
GEEZER
Originally posted by allmotor_2000
On my setup, I have one of those QuikTime Electric Cutouts (you might notice the flange near the flex-pipe). It should offer the extra surge if I happen upon an Italian-type exotic.
#48
Adventurist.
Originally posted by 2003type-s6
Can you have a supercharger AND a turbo on at the same time, or does tis take the place of the S/C??
#49
Originally posted by NiteQwill
It is possible. It's been done on a few VWs in the community. You can have one of each run off each other. The question of engine space is the biggest concern.
One scenario that's interesting would be as follows:
Use a S/C with a electro-magnetic clutch-type pulley. Use the S/C to product power from idle to 4K RPMs. By this time the turbo will be spooled... use a throttle-plate to isolate the S/C charge (kind if like a flap which switches between the turbo and the S/C on the intake side)... disengage the S/C pulley and now you are all turbo! It would be inefficient to run both together... so the moment the turbo starts spooling, the S/C needs to be shut-off. This way you can have a HUGE turbo and not worry about lag. Most folks overcome this by using sequential turbos.
#52
Adventurist.
I just don't think the tranny of a 5AT can handle that power, just too unsafe.
I believe he put a list together of all the parts needed to accomplish this task although he is not marketing it himself.
#54
http://www.velocityresources.com/
Velocity resources makes an upgraded 5AT with hig stall torque converter. I believe they reinforce the transmission with titanium pieces, not sure which pieces though. They can also add in an LSD. A lot of the members over at acur and a-tl have done this upgrade, but be warned it is expensive. But Velocity Resources ensures the tranny and guarantees it to handle up to 600hp!!...I think.
#55
drop em like its hot
600 hp. im guessing the only way to reach that high would be a wet shot...
or with the insanely big ass turbo that we see here in this thread. lol
#56
http://www.levelten.com/store/import...s/acura_cl.htm
anyone have this upgraded tranny on their CL/TL?
#57
Moderator Alumnus
^^^ There has been much talk about the quality of level ten products, or lack thereof. Most people steer clear away from their transmission upgrades.
#59
ex 6 Speed owner :(
Update... added another important part of the kit:
Greddy E-Manage. Installed, awaiting boost
*Special thanks to Scalbert for the sweet custom wiring harness!
#61
That looks great.
I assume it started up and ran just fine with the harness?
BTW, I can send my current program which may help to begin with. I know it will need some tweaking with the FPR settings you guys are running but it would be a start.
#62
That looks great.
That looks great.
The install took a whole 5 minutes - thanks to you!
We spent most of the time measuring oil-lines for the turbo etc.
#63
Underdog
On our motors, either a S/C or a Turbo would, by itself, be sufficient to maximize the engine's capabilities. Even if the motor was highly modified, the incremental gain would not be worth the effort.
#64
13.68 @ 102.56
I'll keep you guys posted as to dyno #s and track results.
#65
I loaded my program on BlueCLS6's and it runs fine - we can't tune that much right now as it serves no purpose!
#66
Originally posted by SCTL-SS
upon completed tuning it will probably be in the 375-385 hp range and after intercooler 400-415 range.
#68
I just emailed the program I am currently using. It can be used as a reference for under boost fuel enrichment.
#70
13.68 @ 102.56
The first thing to see if all the exhaust plumbing can be routed with that hunky 5AT tranny taking up all tha space!!
#72
Originally Posted by BlueCLS6
Another pic. Not very exciting but here are the oil lines for the two cars:
Yes allmotor I finally had them made
Haha... unfortunateley this makes me want to remind you of something else we need completed!
Does that guy have a -10 AN cap? I want to put the oil-pan on sometime and just plug it. That will make installing the turbo a 1-hour job. You might want to do that as well... I am heading out this Sat... so bring that oil-pan along - I'll call you.
#75
Originally Posted by scalbert
I may have asked this before but where are you getting the oil supply from??
#77
They are each just shy of 4-ft each. Due to the turbo placement, the oil-lines are relatively longer than those in most 4-cyl applications. It's the same length as I had before, so I don't anticipate any problems.
#79
Just finished installing the oil-pan and all the oil lines (turbo-ends are plugged-up of course!). I have to check for leaks today... I probably shouldn't have installed it this weekend as I have a long road-trip ahead (to SF area)... and if there was a leak, well I suppose it won't be too bad!
But I think I busted my oil sending unit... the oil light never comes on. I have to do the continuity check recommended in the service manual...
