Is it True about fuel cutoff
Old Aug 9, 2001 | 11:11 PM
2002 3.2 CL's Avatar
On the Acura site it says that the 2001 CL and Type S has a fuel cutoff at6600 and 7000 RPM. But the 2002 TL and Type S doesn't say that it has one. Does the TL have one or just the CL.
Old Aug 10, 2001 | 12:27 AM
GoldTypeS_RENAMED's Avatar
I don't understand how you can have TWO fuel cutoffs?
Since the engines in the TL-S and CL-S are identical, I'm sure the fuel cutoff is the same and it's 7300rpm for both!
Old Aug 10, 2001 | 12:43 AM
mretif's Avatar
the cl-p's fuel cut off might be at 6600 but the cls is past 7000
Old Aug 10, 2001 | 06:37 AM
EricL's Avatar
Originally posted by GoldTypeS:
<STRONG>I don't understand how you can have TWO fuel cutoffs?
Since the engines in the TL-S and CL-S are identical, I'm sure the fuel cutoff is the same and it's 7300rpm for both!</STRONG>
My CLS revlimits at 7300rpm (as near as I can tell).
Here is the excpert from the Helms:
Fuel Cut-off Control
During deceleration with the throttle valve closed, current to the injectors is cut off to improve fuel economy at speeds over 1,100 rpm.
Fuel cut-off action also occurs when engine speed exceeds 6,600 rpm, regardless of the position of the throttle valve, to protect the engine from over-revving.
When the vehicle is stopped, the PCM cuts the fuel at engine speeds over 5,000 rpm.
Comments:
I do know for a fact, that the car has a lower fuel cuttom when "stopped" (in neutral/park).
I think they made a mistake in the Helms about the 6600 rpm, or forgot to mention that this was for the CL (I'm just guessing, since they don't mention the 7300-7400 rpm fuel cutoff in the same paragraph for the CLS).
If you want to look yourself, the page is 11-27 in the Helms CL/CLS manual
I would tend to believe that the fuel is cut-off during deceleration, as this is a common tactic to reduce polution and fuel consumption.
[ 08-10-2001: Message edited by: EricL ]
Old Aug 10, 2001 | 02:57 PM
Originally posted by EricL:
<STRONG>
Comments:
[ 08-10-2001: Message edited by: EricL ]</STRONG>
That makes sense. I forgot about the neutral rev limiter so there are two cutoffs in that sense. But that 6600 thing is definitely a faux-pas.
joflewbyu2
Aug 18, 2019 10:38 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
