a trick to aligning CL mufflers
this will help to make the mufflers height adjustable. you need a couple hose clamps, size 7/8 - 2 3/4".
remove the rubber mount for the muffler (to make it slide off easy spray it w/ some wd40)
place the hose clamp around the rubber mount, then reinstall the mount in a fashion which allows you to adjust the clamp w/ a screwdriver.
once it's back on you should be able to tighten the clamp a few turns and even out your mufflers. it also helps to cut down on the side sway that our exhaust tends to have.
Originally Posted by darrinb
hmm, i dont understand
Matt,
Nice post. I did this several years ago and they ended up snapping. The harsh weather took a toll on those clamps.
The best solution is to get under the car with a piece of pipe and slide the hanger bracket into the opening and bend the sucker into the right spot.
Originally Posted by mattg
doesn't matter. it will work for either.
and mine have been on for months and haven't slipped off the rubber isolator.
Yeah, but I had mine soooo tight, for some reason, one of my exhasut was sitting very low, maybe from when one of the dealers backed up into the curb a few years agao. Friggin idiots. but def a good idea.
IBankMouse
Jun 13, 2020 12:53 PM
emailnatec
29
Sep 28, 2018 04:27 PM
DerrickW
Nov 15, 2015 05:52 PM
johnpancakes014
Sep 27, 2015 12:58 PM
I didn't read to the end.
