a trick to aligning CL mufflers
Old Oct 14, 2004 | 08:54 PM
mattg's Avatar
this will help to make the mufflers height adjustable. you need a couple hose clamps, size 7/8 - 2 3/4".
remove the rubber mount for the muffler (to make it slide off easy spray it w/ some wd40)
place the hose clamp around the rubber mount, then reinstall the mount in a fashion which allows you to adjust the clamp w/ a screwdriver.
once it's back on you should be able to tighten the clamp a few turns and even out your mufflers. it also helps to cut down on the side sway that our exhaust tends to have.
Old Oct 14, 2004 | 08:56 PM
mrsteve's Avatar
Will this also stop them from swaying back and forth?
EDIT: I didn't read to the end.
Old Oct 14, 2004 | 08:59 PM
mattg's Avatar
i have a clamp on both sides and my exhaust doesn't sway.
Old Oct 14, 2004 | 09:02 PM
mclarenf3387's Avatar
Good stuff I'll have to try that.
Old Oct 14, 2004 | 09:03 PM
mrsteve's Avatar
I'll be going to Home Depot tomorrow, thanks Matt!
Old Oct 14, 2004 | 10:07 PM
Allout's Avatar
Blown is Best
Excellent Idea. Send this to the FAQ thread.
Old Oct 14, 2004 | 10:27 PM
Chopsie's Avatar
Beware of leakage
We need after installed pics, Mr. Creative
Old Oct 14, 2004 | 10:42 PM
darrinb's Avatar
///M POWER
hmm, i dont understand
Old Oct 14, 2004 | 10:58 PM
Allout's Avatar
Blown is Best
The clamps will help you control the amount that the exhaust hangers extend thereby giving you adjustability into the height of the exhaust tips.
Old Oct 14, 2004 | 11:03 PM
NiteQwill's Avatar
Adventurist.
Haha, I did this to my VW exhaust, didn't know it would work on this car. Excellent!
Did you buy a set for all the hangers or only the rear?
Old Oct 15, 2004 | 05:22 AM
goldmemberer's Avatar
goldmemberererer
Hm. Anyone got pics or a DIY (for dummies) of how to do it? I noticed my exhaust pipes are hangin a little lower than I'd like, and this sounds so great to do.
Thanks in advance
Old Oct 15, 2004 | 07:23 AM
NSXNEXT's Avatar
Matt,
Nice post. I did this several years ago and they ended up snapping. The harsh weather took a toll on those clamps.
The best solution is to get under the car with a piece of pipe and slide the hanger bracket into the opening and bend the sucker into the right spot.
Old Oct 15, 2004 | 08:40 AM
bent09's Avatar
horny =
pretty smart.... now if I only had exhaust
Old Oct 15, 2004 | 08:59 AM
DHRJDMBA's Avatar
XSESIVE
Most of those clamps can be taken apart fully - you just unscrew it - wrap it around the rubber mount and tighten - saves having to take off the mufflers...
Old Oct 15, 2004 | 09:44 AM
Silverbulit40's Avatar
Enjoy the Ride
good stuff matt!
Old Oct 15, 2004 | 09:46 AM
Chaptorial's Avatar
If this stops the swaying, i'm down!
Nice find.
Old Jan 27, 2005 | 11:08 PM
htown's Avatar
3-piece FTW
matt, can you reupload the pics?
Old Jan 28, 2005 | 01:15 AM
mattg's Avatar
done
Old Jan 28, 2005 | 08:38 AM
rondog's Avatar
Former Sponsor
I tried that, eventually the clamps slip off. So I got rid of the rubber part and just kept metal clamp. that helped.
Old Jan 28, 2005 | 12:29 PM
NSX-Tuner's Avatar
boosted is best
Excellent post... however, is this for the OEM or CT exhaust or does it matter? I can't remember what you've got.
Old Jan 28, 2005 | 12:32 PM
mattg's Avatar
doesn't matter. it will work for either.
and mine have been on for months and haven't slipped off the rubber isolator.
Old Jan 28, 2005 | 04:53 PM
mrsteve's Avatar
Still haven't gotten off my lazy ass and done this... I suX0r
Old Jan 28, 2005 | 09:51 PM
rondog's Avatar
Former Sponsor
Yeah, but I had mine soooo tight, for some reason, one of my exhasut was sitting very low, maybe from when one of the dealers backed up into the curb a few years agao. Friggin idiots. but def a good idea.
Old Jan 28, 2005 | 09:55 PM
typeR's Avatar
not to rain on your parade but i think my way might be better... 2 hangers F/R on the side that hangs low...mine have been on for 3 years
Old Jan 28, 2005 | 11:44 PM
mattg's Avatar
you mean 2 rubber mounts on each hanger?
Old Jan 29, 2005 | 10:06 AM
typeR's Avatar
yes
IBankMouse
Jun 13, 2020 12:53 PM
emailnatec
29
Sep 28, 2018 04:27 PM
DerrickW
Nov 15, 2015 05:52 PM
merc009
Sep 29, 2015 03:06 PM
johnpancakes014
Sep 27, 2015 12:58 PM
