Transmission Question for Scalbert
Old Jul 15, 2002 | 11:03 PM
Mint Julip's Avatar
Scalbert,
Greetings! I just took delivery of a B&M trans cooler, and since you're the resident expert, I'd like to know which one of the lines on the transmission is the feed line to the trans cooler.
Thanks in advance!
Mint
Old Jul 15, 2002 | 11:22 PM
Rescuer's Avatar
Evil Bob Knieval
http://www.acura-cl.com/forums/showt...threadid=62311
http://www.acura-cl.com/forums/showt...threadid=62994
http://www.acura-cl.com/forums/showt...threadid=64043
Old Jul 16, 2002 | 12:08 AM
AztecRol's Avatar
The Screeching Toyo's
DAYUM DOOD!!! Next time I have a question, I will hit the PM TypeSDragoon button instead of the SEARCH button!!!
Old Jul 16, 2002 | 08:22 AM
scalbert's Avatar
Obviously very well answered by TypeSDragoon. Just let me know if anything isn't clear.
Old Jul 16, 2002 | 08:24 PM
Mint Julip's Avatar
Guys,
Thanks for the info. Scalbert, I reviewed your previous posts regarding flow direction and have the following questions:
1. Were you able to confirm that the ATF flows from the ATF filter (front of trans) and drains into the ATF hose assy (back side of trans facing firewall)? In other words, confirming your original assumption that ATF is flowing from front to back?
2. In the pre-cooler install pics, which one is feed (to the cooler)?
Thanks again -
Mint
Old Jul 16, 2002 | 08:32 PM
Rescuer's Avatar
Evil Bob Knieval
Old Jul 17, 2002 | 07:47 AM
scalbert's Avatar
I never verified flow direction but I suspected front to rear flow. But due to the limited points of connection I found the flow direction to be irrelevant. The cooler doesn't care which is the inlet or the outlet.
The only real concern to me would be during the installation, does it flow through the filter after the cooler to catch any debris which might have been in the cooler or lines. I took that as a small risk and went ahead; drove thousands of miles with a more consistent shift quality.
Yikes
May 3, 2021 04:29 PM
pstomps
Feb 20, 2017 03:29 AM
BoricuaTL
Apr 8, 2016 01:08 PM
ghuns
Sep 16, 2015 04:26 PM
datadr
Sep 12, 2015 09:12 PM
