transmission problem solution
Old Jun 4, 2013 | 04:23 PM
cl82793's Avatar
as i know trannies in our cars is the major concern,i came accross this article. it supporst the fact that "heat is the root of transmission failures"(aside from the fact of mfg defects) but i have read a lot of articles here and others , and this just makes sense along with other prcautions)3x3 change etc.)
let me now your opinions.
http://www.mdxers.org/forums/18-main...intenance.html
Old Jun 4, 2013 | 07:43 PM
YeuEmMaiMai's Avatar
trans cooler will not solve the problem. removing the internal filter will not solve the problem.
enlarging the 3rd gear clutch pack lubrication channel WILL solve the problem.
Old Jun 5, 2013 | 10:15 AM
harvthesecond's Avatar
Any auto car I come in to possession of gets a trans cooler as quickly as possible. Just a bit of preventative.
Old Jun 5, 2013 | 05:06 PM
fsttyms1's Avatar
But in our case, it wont fix the problem or prolong its life.
Old Jun 5, 2013 | 07:39 PM
Waste of time and money..... We know what the problem is and it is too little oil flow to the 3rd gear clutch pack. The fluid temps reach < 315F and this is what kills the transmission. You can read about it in the stickey transmission faq
Old Jun 7, 2013 | 11:28 PM
Dead-Fox's Avatar
Is there a driving style that causes more overheating of the transmission?
Old Jun 7, 2013 | 11:34 PM
yes
lots of stop and go with heavy 2-3 shifting or just flat out hard on the car.
Old Jun 11, 2013 | 01:52 AM
Dconnor's Avatar
9th Gear
I'm somewhat of a nood but i know that your right on that one
ive been threw it enough times nd ive told the tranyguys the same damn thing wich ofcourse they take offence to ,
have you heard of anyway for that to actualy be done and the capilaries widened?
Old Jun 11, 2013 | 12:48 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
If u have a cooler temps go down to 215 on a hot day in traffic. So a cooler makes a shit load difference. Especially cause when we have a trans warmer in our transmissions so it really helps balance out the temps. I have a cooler and I have a temp gauge which is insulated and in the trans fluid so it makes a big difference.
The real problem is putting a cooler on after the fact doesn't mean the transmission has not already suffered from too much heat... Therefore thecooler becomes a band aid. But if u get the trans rebuilt And have a cooler from the start u will be in a much much better scenario. Which I is what I did on the 2nd rebuild I have done. First one lasted 28000kms. Second one I am at arpx 80000kms already and it shifts like a beast. Mind u I do have upgrades clutches seals and whatever else is in their. But I can guarantee the cooler is a must.
Old Jun 12, 2013 | 11:36 PM
aerouta's Avatar
6th Gear
this applies to automatic transmission only correct?
Old Jun 24, 2013 | 05:02 PM
aznboi2424's Avatar
Yes, no such concerns for the MT
Old Jun 24, 2013 | 06:21 PM
TheWeez's Avatar
I Wanna Beer
This. The Acura's transmission is not a heat issue. It's a design flaw. If someone was to make a shift kit it may resolve the issues but at this point no one has and very likely never will. With my old SHO they had lots of automatic transmission issues. Installing a simple $30 shift kit (couple springs and drill a couple holes) increased lubrication more than double than the factory standard and made the tranny pretty much bullet proof in addition to offering a white spring for neck snapping shifts at full throttle. Too bad there hasn't been anything like that for the CL.
Old Jun 25, 2013 | 05:59 PM
OperationDarkie's Avatar
Ultra Negro
This times infinity, all you are doing is cooling the oil that ISN'T getting to the 3rd gear clutch pack honestly.
Old Jun 28, 2013 | 11:31 PM
99 Chris's Avatar
I like peanut butter
So question .. I had my auto transmission rebuilt ~14k miles ago (at the 52k mark on my 2001 CL). The shop gave the typical 2 yr/24k mile warranty. I can already tell it's going to need a rebuild again, and will make sure this happens while under the warranty. Can I tell them to modify the tranny for this 3rd gear "more fluid" issue? Or are they going to look at me like I don't know what I'm talking about and ignore my request? And should I go ahead and add a transmission cooler while it's in the shop (maybe a gauge for shits & giggles too)?? If I'm going to keep this car another few years, or longer, I'd like a better guarantee the tranny is good and no more worries! I know these cars are good for hundreds of thousands of miles otherwise. Also have heard it's the quality of the Acura internals. Is there an aftermarket internal "kit" I should request as well?
Old Jun 30, 2013 | 04:56 AM
Anicra's Avatar
yes
Funny thing, My wife drove the car to work everyday for 7 years (Mainly, stop and go) and I drove the car most of time when we were together. I am a spirited driver. I pushed the Acura CL pretty hard on highways.
Transmission finally died 151K, we spent 3k to get it running. The car was in excellent shape.
Very odd how it worked out for us.
cycdaniel
Dec 17, 2019 10:58 AM
spidermankb
Mar 5, 2019 11:34 AM
pstomps
Feb 20, 2017 03:29 AM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
