transmission drain bolt specs
Old Mar 31, 2011 | 12:43 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
does anyone know the drain bolt specs for the 01 cl-s auto transmission.
i'm trying to get a reducer to put my transmission temp gauge in that location instead of running it in-line with the cooler hose.
when i drive i think the air is cooling the readings more than cooler is actually doing... (i think) so i'm looking to change where the sensor is located.
if anyone knows the specs to that friggin bolt i'd be quite thankful
all i know is it's an 18mm that All ACURA could tell me. stupid monkeys
Old Mar 31, 2011 | 02:52 PM
whiteknight's Avatar
If someone does not answer by the time I get home tonight I will let you know. It is in the shop manual.
Old Mar 31, 2011 | 10:59 PM
All the manual indicates is that it is an 18 x 1.5 mm bolt.
Old Apr 1, 2011 | 02:40 PM
1.5mm is the thread spacing i think thanks.. that's what i needed
cobra10363
Jul 23, 2024 04:13 PM
Yikes
May 3, 2021 04:29 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
ghuns
Sep 16, 2015 04:26 PM
