Trans Switch Part Numbers Help
I just acquired a clean well running 2001 CL Type-S (auto) for my 16 yr old daughter. It has 150k mi and I’m pretty sure it’s still on the original transmission and timing belt! I got it from my sister and she’s owned it for quite a few years and said all she ever did was change the oil and brake pads and tires. She said it had 80k on it when she got it...
I’ve already ordered the Aisin timing belt kit and I have a case of Honda DW1 to do a 3x3. I also got a new transmission filter. I want to get the 3rd and 4th gear transmission switches and I am having a hard time finding the exact part numbers for both. Can someone give me the exact part numbers for these 2 items? Thanks in advance!...
I’m seeing a lot of different ones on eBay with different part numbers and some listings say compatible and others don’t. Are these switches the same for 2nd and 3rd gens?...(TL and CL)
28600-P7Z-003
28600-P7W-003
or
28600-RAY-003
28610-RAY-003 ???
28600-P7Z-003
28600-P7W-003
or
28600-RAY-003
28610-RAY-003 ???
Ok I dig around the 10,000 posts on here and I’m only slightly less confused...
could someone verify if these 2 switches are what I need for
2001 CL-S automatic?
28600-p7w-013
28600-p7z-013
thanks
28600-p7w-013
28600-p7z-013
thanks
I guess I’ll reply to myself again and ask another question.
i received the parts today but the colors don’t match the originals...the originals were black as the 3rd gear switch and beige as the 4th gear switch.
part numbers I ordered and received were:
28600-p7w-003 (4th gear) BLACK
28600-p7z-003 (3rd gear) GREEN
Does the color matter?...It seems I’m supposed to replace the old black with the new green, and the old beige with the new black...
In the interest of replying, if you have correctly identified the above part numbers as the correct ones for your third&fourth gear automatic application, then I would rely more on that then the 'color' they may happen to be upon delivery. Those colors may have change over the years, for whatever reason(like multiple applications ), for your 18+ year old car.
I have a CLS six speed, so I'm not really sure.
98BlueStreak
1G CL Problems & Fixes
02-12-2013 03:52 PM
InfamousJamous
1G RDX DIY & FAQ
06-27-2011 08:45 PM
I hate cars
08-05-2007 02:43 AM
