tranny probs
Old Jan 30, 2007 | 09:00 AM
OrngeAc3.2's Avatar
tranny probs
so i have been reading here and there how bad our trannies are-->bought my car used, and my warranty is up....i would like to stay on top of things so i dont get screwed with a big problem...can i have some input as to what i should be checking/looking for to make sure i dont get it in the "tail pipe"??
thanks
Old Jan 30, 2007 | 09:16 AM
hemhaw's Avatar
Drinking Beer In
It's really russian roulette. You can change/partially change/flush the ATF often, but at the end of the day, these things can fail no matter what you do.
If your ride has >109,000 miles on it, it either has already gone through a tranny or 2, and so has far fewer miles on the transmission, OR if it is the original one, then it must be a "good" one.
If you know for a fact that it is the original one, you could verify that the oil jet retrofit was done.
In any event, I wouldn't sweat it. There's really nothing you can do to prevent the failure, and the majority of them don't break anyway.
Old Jan 30, 2007 | 09:36 AM
OrngeAc3.2's Avatar
good look
it's got 83k on it and runnin strong- at times i would jump on it and feel a slight delay but thats only when i "punch" it, but i rarely ever do that
thanks for the input, ill keep an eye out-->wish me luck
Old Jan 30, 2007 | 09:56 AM
RaviNJCLs's Avatar
You still have time. There are a MUCH higher percentage of cars that have and probably will never experience failures.
There really isn't much you can do to prevent it.
Old Jan 30, 2007 | 01:45 PM
spiderman3098's Avatar
i have 150 000 miles and not a single problem when it started gettin rough i bought a can of seafoam tranny fluid put it in and a week later flushed out the atf fluid and replaced with genuine honda atf and it shifts flawlessly now and i got like 5000 miles on it since then and it hasnt got any worse since that day so idk keep up with regular maintenance and you should be good. Unless u got a bad tranny and then got like the shittiest one of the bad ones. but if you got that many miles on it already it aint goin anywhere to soon.
Old Jan 30, 2007 | 03:10 PM
hemhaw's Avatar
Drinking Beer In
thanks
Your Warranty is NOT up. Acura extended the tranny warranty to 100K because of these problems. And a recent class action judgment is pushing this out to 109K.
Pham Alvan
May 18, 2021 06:48 AM
Charles Bennett
Jan 28, 2018 08:53 PM
Pham Alvan
Mar 16, 2016 09:17 AM
lanechanger
Oct 13, 2015 10:56 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
