tranny going maybe????????????help
guys when your tranny started to go what were the signs???????? i got on my car and let it shif itself when thru 1st 2nd and when it shifted in to 3rd i heard it slip alittle i think. did you guys experience this thanks ...................
Originally Posted by sgmotoring
You can't hear your tranny slip a little.
If you hear your trans slip, you are actually hearing your engine rpm bouncing of the rev limiter.
My Member is Registered
that is one of the issues with this car, the shift points lag between shifts, causing a huge heat build up. You will know it when it starts to go. Do some searching in the proper forum (transmissions) and you will find all the info you need.
I do not drive my wife's 01 CL-P. So I am uncertain exactly how long the "slipping" was going on. BUT- especially when cold it was slipping major between 1-2 and half as bad between 2-3. It also seemed to lug a bit, not quite lurch, as it hunted for a decel downshift.
Immediately I dropped it off at the local Acura Stealer . . .err...Dealer, and they called me to say 7-10 day wait until a "new" tranny comes in.
It is a warranty item.
They offerred a rental car - no Acura, in the meanwhile.
F.Y.I. from Williamstown, N.J.
They offerred a rental car - no Acura, in the meanwhile.F.Y.I. from Williamstown, N.J.
Pham Alvan
May 18, 2021 06:48 AM
Pham Alvan
Mar 16, 2016 09:17 AM
lanechanger
Oct 13, 2015 10:56 AM
