tranny fluid question
Old Apr 12, 2006 | 04:52 PM
GenXET's Avatar
If I want to do a drain and fill, how many quarts of tranny fluids do I need ?
Old Apr 12, 2006 | 08:19 PM
GreenMonster's Avatar
PM Nighthawkblue.... He knows the deal w/ the automatics...
https://acurazine.com/forums/audio-video-electronics-navigation-22/attn-ron-174812/
Old Apr 13, 2006 | 02:37 AM
aveisone's Avatar
for an 03cls its 2.3 US qt of honda atf-z1
for the six speed its 2.3 of honda manual transmission fluid
Old Apr 14, 2006 | 06:35 PM
SodaLuvr's Avatar
3 qts.
If you're already on your remanufactured, updated unit, do a 3x drain/refill or a DIY Flush (drain/refill, disconnect both lines, start car and allow 3 qts to come out, refill, repeat) with a synthetic ATF such as Amsoil ATF or Specialty Formulations ATF-Z1 in attempt to prolong the life of the unit. The Honda ATF-Z1 turns brown very quickly, whereas these two do not seem to have the same problem. If you do a full flush with either of those fluids, a flush every 60K should be fine.
Old Apr 14, 2006 | 09:39 PM
99YA3CL's Avatar
Registered Whore
3 Qts For 2.2, 2.3 Auto. Use Genuine Honda/acura Atf.
Old Apr 14, 2006 | 10:50 PM
CleanCL's Avatar
3.1 qt
pick up 4 qts at acura, cost me like 22 and change, i use 3 full quarts and about 1/4 of the 4th one.
Old Apr 16, 2006 | 10:07 PM
GenXET's Avatar
i just changed mine... did the drain and fill 2 times
my friend works at Honda dealership and hooked me up with some tranny fluid for $26.xx for 6 bottles
hopefully my original tranny will last for another few years
Yikes
May 3, 2021 04:29 PM
ghuns
Sep 16, 2015 04:26 PM
datadr
Sep 12, 2015 09:12 PM
HeloDown
Sep 8, 2015 06:51 PM
jfman55
Sep 5, 2015 02:55 PM
