tranny fluid question
PM Nighthawkblue.... He knows the deal w/ the automatics...
https://acurazine.com/forums/audio-video-electronics-navigation-22/attn-ron-174812/
3 qts.
If you're already on your remanufactured, updated unit, do a 3x drain/refill or a DIY Flush (drain/refill, disconnect both lines, start car and allow 3 qts to come out, refill, repeat) with a synthetic ATF such as Amsoil ATF or Specialty Formulations ATF-Z1 in attempt to prolong the life of the unit. The Honda ATF-Z1 turns brown very quickly, whereas these two do not seem to have the same problem. If you do a full flush with either of those fluids, a flush every 60K should be fine.
i just changed mine... did the drain and fill 2 times
my friend works at Honda dealership and hooked me up with some tranny fluid for $26.xx for 6 bottles
hopefully my original tranny will last for another few years
HeloDown
09-08-2015 06:51 PM
